I'm looking for the software that does the best job of just displaying the input from the card, straight to the monitor in full screen.
If possible, display it exactly as it comes in, but at least with the highest possible frame rate and resolution, with minimal lag.
So far, VLC has not been working with the capture card
CaptureFlux is working with its full-screen preview, although there's a couple of problems, and the frame rate it only manages 25fps, where I'm pretty sure the capture card is getting 30fps
It doesn't seem like much of a task for software to do, but relying on capture card software "preview" may not be the most optimal solution.
I basically just want to use the card to allow me to use RCA-out devices on my LCD monitor
Can anyone recommend any software?
Adam.
Would this "card" be an Ace of Spades, perhaps?
Maybe it's a Hallmark card?
A business card?
Oh, it's a CAPTURE CARD. Well, then, THAT provides just ALL the information anyone would need to know. With all that detailed information, it seems obvious that the software you should use would be CAPTURE CARD SOFTWARE. -
Composite input to a generic capture card needs hardware conversion (Y/C separation, NTSC/PAL decode to Y,Pb,Pr) then A/D to Y, Cb, Cr components for file capture. Preview is an on the fly is a YUY2 to RGB conversion. The driver software will usually show this in a 640x480 preview window. You can choose "full Screen" for the display card to upscale to monitor resolution.
If yours is only making 25 fps, it is either set for PAL or doing some kind of software upscale. Use something else.Last edited by edDV; 8th Jan 2011 at 16:37.
http://www.kiva.org/about
Dual Input LED Monitor
By blinky88 in forum ComputerReplies: 15Last Post: 28th Apr 2011, 10:23 -
Dual Input display in a single monitor
By torrentkid in forum DVB / IPTVReplies: 1Last Post: 26th Jul 2010, 06:43 -
GL2 LCD Monitor Display
By HarveyCee in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 27th May 2009, 17:32 -
Sigmatel input monitor issues
By GLE3 in forum AudioReplies: 2Last Post: 14th Mar 2009, 16:25 -
TV Tuner Display on Secondary monitor?
By wakarusensei in forum DVB / IPTVReplies: 4Last Post: 6th Dec 2008, 15:51
