    Mar 2009
    Iowa, USA
    I am trying to convert videos to play to my Sony KDL-32EX308 but can't seem to get it to work. Sony's website states that the TV only plays AVCHD and MPEG2 via network or USB flash drive but gives no specs on container or other settings. I'm converting to MPEG2 but the files still won't play. Is there specific encoding options I need to use? I am using ffmpeg via CLI (openSUSE); I have also tried avidemux. I do have a Windows 7 machine in the house and XP dual booted on my laptop if I have to resort to it.
    I'm hoping someone knows what I'm doing wrong or not doing at all.
    Thanks for any help!
    I used media info to get stats on the most recent file I converted:
    General
    Complete name : /media/disk-7/clash_of_the_titans_2010.mpeg
    Format : MPEG-PS
    File size : 3.70 GiB
    Duration : 1h 46mn
    Overall bit rate : 4 997 Kbps
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings, BVOP : No
    Format settings, Matrix : Default
    Format settings, GOP : M=1, N=18
    Duration : 1h 46mn
    Bit rate mode : Variable
    Bit rate : 4 449 Kbps
    Nominal bit rate : 9 000 Kbps
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 16:9
    Frame rate : 29.970 fps
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.430
    Stream size : 3.30 GiB (89%)
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Duration : 1h 46mn
    Bit rate mode : Constant
    Bit rate : 448 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 340 MiB (9%)
  2. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Well, that sucks!
    Sony doesn't usually play mainstream formats, only ones coming from a Sony product.
    Mar 2009
    Iowa, USA
    Yeah, should have done a little more research on format support. crap sony &%$*#&@!
    I suppose next I'll have to buy a Vaio laptop and a Sony licensed surge protector. Maybe even a sony wall socket and sony WiFi router too!
  4. Maybe it doesn't like program streams? Try remuxing into a transport stream? Maybe it doesn't like AC3 audio in a program stream?
  5. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    I think ".M2TS" is the Sony transport stream.
  6. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Most Sony manuals detail codec and container support specs.
    AVCHD format is specific on codec (MPeg2, h.264, VC-1), max bit rate and file structure.
    Alternate is an external media player.
    http://www.kiva.org/about
  7. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Details? That's where the devil is.
    Sony is just like Apple, they will tell you they play ".MP4" and that's about it. And they put a bunch of stickers and logos making you think it's all good and the kitchen sink too.
    Sometimes they just make up stuff. Like "Exclusive Sony EIOS technology" or "DLNA", and then glue a shiny sticker extrolling the virtues of nothing special.
    Sony can make a bag of poop look and smell like a flower with their "Sony Style" makeover.
    Whew!
    Jun 2008
    My Sony kdl - 46EX700 actually plays MT2S, DIVX and MPEG2 files through its USB port without any trouble.
    Perhaps you wish to upload a 10 seconds sample to MEDIAFIRE.COM so that I download it and try it on my tv set.
