I have a very large avi that i need to compress so i can upload it to youtube in a reasonable amount of time. It was rendered at 1600x900 but I just need to keep it good quality at 720p so my viewers can actually see what im doing without squinting. The software im using is Sony Vegas Pro 10.
Here is info on the file:
Video
Format : YUV
Codec ID : UYVY
Codec ID/Info : Uncompressed 16bpp. YUV 4:2:2 (Y sample at every pixel, U and V sampled at every second pixel horizontally on each line). A macropixel contains 2 pixels in 1 u_int32.
Duration : 25mn 22s
Bit rate : 691 Mbps
Width : 1 600 pixels
Height : 900 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:2
Compression mode : Lossless
Bits/(Pixel*Frame) : 16.000
Stream size : 122 GiB (100%)
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Codec ID/Hint : Microsoft
Duration : 25mn 22s
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 279 MiB (0%)
Interleave, duration : 250 ms (7.49 video frames)
Interleave, preload duration : 250 ms
Try StreamFab Downloader and download streaming video from Youtube, Netflix, Amazon! Download free trial.
I searched for "squint-free" on YouTube and came up with nothing. YouTube does suggest these codecs and containers for uploading:
http://www.google.com/support/youtube/bin/answer.py?answer=55744
The most common codec used is most likely H264 with AAC audio. I use a variety of programs to get me to H264/AAC....VirtualDub, AviDemux...and sometimes MainConcept. I rarely upload anything larger than 640x480 though....it's only YouTube. -
first you'll have to cut it up. youtube had a 10 minute limit but i thinks it's now 15. they prefer mp4 video with mp3 or aac audio. there is a decent vegas preset for the tube. choose sony avc as the renderer and select the internet 720p template. customize it with a higher bitrate. 5mbps will get the HD link, i usually go up to about 8mbps for better source quality. up to you, the higher the bitrate the bigger the file to upload, with some slight increase in tube quality after they re-encode it.
Compress large FLV file to a smaller size FLV file
By RustyBob in forum Video ConversionReplies: 1Last Post: 26th Oct 2011, 18:21 -
Help to compress large HD File
By camlachie in forum Video ConversionReplies: 10Last Post: 10th May 2009, 13:47 -
How to compress FRAPS capture for YouTube upload?
By ReiKo90 in forum Newbie / General discussionsReplies: 10Last Post: 4th Feb 2008, 10:12 -
Mpeg too large to upload on youtube?
By nadizo in forum Video ConversionReplies: 2Last Post: 31st Oct 2007, 16:13 -
How do I compress a large .FLV file to a smaller .FLV file
By goheadtry in forum Newbie / General discussionsReplies: 2Last Post: 8th Aug 2007, 01:13
