    Dec 2010
    Canada
    Everytime I try to convert in xvid4psp I end up with a message saying that x264.exe has crashed. And not just with one file type, it happens with .mkv, .avi, .mp4. etc. It worked fine for months until it randomly stopped working a couple of days ago. I hadn't even installed anything new. Security Center also randomly stopped working but I'm not sure if that's related. I don't have any viruses as I've scanned with Malwarebytes, avast!, Hitman Pro, Combo Fix, and Spybot. My registry is clean, my temp files are cleared out. I have no idea what could have gone wrong.
    I'm running Windows 7 Ultimate 32 bit, AMD Athlon X2 4400+, NVIDIA GeForce 6150SE nForce 430, with 3GB RAM. I know it can't be an incompatibility with my hardware because it worked for months before. My UAC is on but I don't think that's relevant as again, it worked before.
    Here's a log in case it helps.
    PLATFORM
    OS: Microsoft Windows NT 6.1.7600.0
    OEMCodePage: 850
    Language: ENC
    DecimalSeparator: .
    Framework: 2.0.50727.4952
    Processors: 2
    Machine: **** (Private + Irrelevant)
    UserName: **** (Private + Irrelevant)
    SystemDrive: C:
    XVID4PSP
    Version: 5.0.37.6 rev65
    Created: 20/11/2009 11:37:18 AM
    TempPath: C:\Temp
    AppPath: C:\Program Files\Winnydows\XviD4PSP5
    FILES
    [UTW-Ryuumaru] Yosuga no Sora - 01 [720p][E60353CB].mkv >
    [UTW-Ryuumaru] Yosuga no Sora - 01 [720p][E60353CB].mp4
    TASK
    Format: MP4 iPhone or Touch
    Duration: 00:25:54:012 (37259)
    VideoDecoder: DirectShowSource
    Resolution: 1280x720 > 480x272
    VCodecPreset: x264 Q21 HQ
    VEncodingMode: Quality
    VideoCodec: h264 > x264
    VideoBitrate: 1987 > Q21.0
    Framerate: 23.976
    SourceType: PROGRESSIVE
    FieldOrder: UNKNOWN
    AudioDecoder: bassAudioSource
    AEncodingPreset: AAC-LC ABR 128k
    AudioCodec: AAC
    AudioBitrate: 0 > 128
    Samplerate: 48000
    Channels: 2
    Normalize: 100%
    Accurate: 3%
    Gain: 3.586
    SCRIPT
    import("C:\Program Files\Winnydows\XviD4PSP5\dlls\AviSynth\functions\ AudioFunctions.avs")
    import("C:\Program Files\Winnydows\XviD4PSP5\dlls\AviSynth\functions\ VideoFunctions.avs")
    loadplugin("C:\Program Files\Winnydows\XviD4PSP5\dlls\AviSynth\plugins\ba ss\bassAudio.dll")
    video = DirectShowSource("C:\Users\Mary\Downloads\Complete d Downloads\To be Converted\[UTW-Ryuumaru] Yosuga no Sora - 01 [720p][E60353CB].mkv", audio=false, fps=23.976, convertfps=true)
    audio = bassAudioSource("C:\Temp\0000_0.aac")
    AudioDub(video, audio)
    AutoYV12()
    Lanczos4Resize(480, 272)
    AmplifydB(3.586)
    VIDEO ENCODING
    Encoding video to: C:\Temp\0000.264
    x264 Q21.0 480x272 23.976fps (37259 frames)
    x264.exe: --crf 21 --level 3.0 --ref 6 --deblock -1:-1 --bframes 0 --weightp 0 --no-mixed-refs --no-cabac --no-fast-pskip --partitions p8x8,b8x8,i4x4 --no-8x8dct --me umh --rc-lookahead 60 --sar 1:1 --output "C:\Temp\0000.264" "C:\Temp\0000.avs"
    Error:
    And for the record, I've tried several versions of xvid4psp: r132 unofficial, as well as every official version.
    Also I've tried different profiles and output formats.
    And if this has been solved before I don't want any crap about it. I looked around, ran a search, etc and found nothing helpful.
    Oh and no way in hell will I format my PC. I'd simply give up if I have to do that.
    Also I don't want to hear about alternatives for converting anime with subtitles unless you have something equally as simple and effective that preserves formatting, I already have an alternative it just doesn't preserve the formatting.
    I would guess it's something wrong with a video decoder/codec. xvid4psp uses avisynths directshowsource and it uses your installed decoders. Maybe try uninstall all codec packs/etc and reinstall ffdshow.
    Dec 2010
    Canada
    alas that was one of the first things I tried.
    I'll try an encode using avisynth without xvid4psp, I was having trouble importing audio earlier with bassaudiosource but I fixed it. However I like xvid4psp because it converts straight to my desired format usually without much hassle or loss of quality. Plus it can do batch conversions in a couple of clicks.
    EDIT: And we have success. It's clearly nothing wrong with the decoders, it's probably a problem with the encoder. But what perplexes me is why it suddenly stopped working despite working flawlessly before.
    EDIT2: Well now that's peculiar. It started working again after I ran another Auslogic, guess it was just a disc error causing my problems. I guess.. problem solved? And if it stops working again I have my very roundabout alternative, haha.
    Last edited by hasteroth; 30th Dec 2010 at 21:59. Reason: Problem Solved on account of Black Magic.
