Hello.
I just bought a Logik L22DVDB20. It's a television with a built-in slot DVD player. I'm hoping to make it multiregion if possible so I can disconnect my regular DVD player. Anyone know of any hacks? It's currently region 2.
Any help would be great, thanks.![]()
Thread: Region Hack - Logik
Aww I was hoping I might be able to. I know you can with the Logik players. No chance at all?
If you can't find a specific hack for your model, as a last resort you could try hacks for other models from the manufacturer, for example:
http://forum.videohelp.com/threads/272665-Logik-LD3330-Multi-Region-help-plz -
Oh that's not what I meant, I was just disappointed. I think it's a fairly new model so it could be no one's figured it out yet if there is one. I did check the links on the leftbar for my model before I posted.
Thanks.
I did look at that one actually, wondering if it might work for mine. I don't have a tray though, it's a slot.
Yes there is... and it's very very easy.
Select DVD as the source, then type in 9735, with the arrow keys on the remote choose region 0 then exit menu and your done.
Enjoy.... and don't let anyone say Middlesbrough boys are not friendly!! -
You sir, are awesome.
It's actually the same code that's on the link someone else posted above, but I looked at the model that went with and it was one with a tray so I thought it wouldn't work.
I owe you thanks and him an apology. But yay! It even plays my Reg 1 RCE Knight's Tale now and some hacks don't allow that to play (it's a good one to test because if it's not going to play it shows a map of the world rather than just leaving you wondering if the blank screen will go away).
Now if I could just get it to not make the scary grinding noise as it accepts and ejects the disks......
Logik LPD1008 hack
By lee200 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 25th Sep 2009, 04:35 -
Logik LPD860E multi region HELP plz
By birgittalb in forum DVD & Blu-ray PlayersReplies: 2Last Post: 19th May 2009, 17:49 -
Logik LD3330 Multi Region help plz
By jon120 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Jun 2008, 17:19 -
Hack for LOGIK LM101DU needed!
By emerve in forum DVD & Blu-ray PlayersReplies: 1Last Post: 2nd Jan 2008, 12:57
