My friend has bought a laptop Qosmio X505, Win 7, 64-bit, CPU i7, 18.3" display. Looks really nice but personally I wouldn't buy such one. Too big and too expensive. Moreover, he has no clue about computers at all. Sounds funny, doesn't itSo, in my spare time I show some computer basics for him (I'm not a computer geek either). But let's get to the point.
On his beautiful laptop playing one specific AVI file in WMP there's no audio at all. The same file plays in MPC-HC with no problems (audio and video). I've installed AC3Filter to his system and still no audio playing back same video in WMP. I checked in the list of >associate a file type...< and there was no .ac3 extension at all. Weird...
I checked this AVI by GSpot and can't see any problem. Shows needed codecs installed.
He want to play videos back in WMP... Let it be his way.
I know I don't have to worry about this. That's not my computer. But
1) he is a friend of mine
2) and out of my curiosity
BTW: His other AVIs playback in WMP with no problem. But I can't say for now - was in the other AVIs AC3 audio or some different format - can't remember. I can check it out in a couple hours if this is a crucial thing.
EDIT: The other AVI files with AC3 audio play back in WMP with no problem. Just this file doesn't have any sound. That's what I don't understand
General
Complete name : C:\Users\...........\Documents\So Weit Die Füße Tragen
Format : AVI
File size : 701 MiB
Duration : 1h 18mn
Overall bit rate : 1 247 Kbps
Writing application : Nandub v1.0rc2
Writing library : Nandub build 1852/release
Video
Format : MPEG-4 Visual
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 18mn
Bit rate : 1 013 Kbps
Width : 544 pixels
Height : 304 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.245
Stream size : 570 MiB (81%)
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 2000
Duration : 1h 18mn
Bit rate mode : Constant
Bit rate : 224 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 126 MiB (18%)
Alignment : Split accross interleaves
Interleave, duration : 40 ms (1.00 video frame)
Interleave, preload duration : 500 ms
Results 1 to 1 of 1
Help regarding playing specific video file in WMP
By sohaibrazzaq in forum Software PlayingReplies: 4Last Post: 25th Sep 2011, 12:19 -
anybody had any luck with playing divx softsubs in Wmp 11 ?
By davexnet in forum Software PlayingReplies: 1Last Post: 12th May 2011, 01:02 -
Playing flv files with WMP
By INFRATOM in forum Software PlayingReplies: 1Last Post: 22nd Jan 2009, 03:12 -
Playing AVCHD on plasma using WMP=wrong AR
By EliG in forum Camcorders (DV/HDV/AVCHD)Replies: 5Last Post: 29th Oct 2007, 11:54 -
Playing wmp music samples at Amazon
By NiteLite in forum Newbie / General discussionsReplies: 19Last Post: 12th Aug 2007, 14:02
