    Hello, I have been trying to encode this .ts file into a DVD compatible .mpg file. Whenever it is encoded the audio is behind the video. I have tried mpeg2repair, but it still is out of sync. When I put the .ts file into an .mpg file it still has this problem. without AVStoDVD I still have this problem.
    Here is the info for the original .ts file
    General
    ID : 1 (0x1) Complete name : C:\Users\Nathan\Desktop\Rick Steves' European Christmas Best Version.TS Format : MPEG-TS File size : 6.62 GiB Duration : 1h 56mn Overall bit rate : 8 147 Kbps
    Video
    ID : 68 (0x44) Menu ID : 1 (0x1) Format : MPEG Video Format version : Version 2 Format profile : Main@High Format settings, BVOP : Yes Format settings, Matrix : Default Format settings, GOP : M=3, N=15 Codec ID : 2 Bit rate mode : Variable Bit rate : 7 163 Kbps Nominal bit rate : 38.8 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 29.970 fps Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Compression mode : Lossy Bits/(Pixel*Frame) : 0.115 Stream size : 14.7 ?iB
    Audio #1
    ID : 69 (0x45) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Codec ID : 129 Duration : -24h 34mn Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Delay relative to video : -831ms Stream size : 2.05 ?iB Language : English Name : en:Primary Audio
    Audio #2
    ID : 72 (0x48) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Codec ID : 129 Duration : -24h 34mn Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Delay relative to video : -738ms Stream size : 2.05 ?iB Language : English Name : en:Secondary Audio
    Audio #3
    ID : 73 (0x49) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Codec ID : 129 Duration : -24h 34mn Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Delay relative to video : -808ms Stream size : 2.05 ?iB Language : English Name : en:Secondary Audio 2
    Text #1
    ID : 68 (0x44)608-1 Menu ID : 1 (0x1) Format : EIA-608 Muxing mode : A/53 / DTVCC Transport Muxing mode, more info : Muxed in Video #1 Stream size : 0.00 Byte (0%)
    Text #2
    ID : 68 (0x44)1 Menu ID : 1 (0x1) Format : EIA-708 Muxing mode : A/53 / DTVCC Transport Muxing mode, more info : Muxed in Video #1 Stream size : 0.00 Byte (0%)
    Here is the info for the output file for the AVStoDVD .mpg file
    General
    Complete name : C:\Users\Nathan\Videos\DVD_0_Rick Steves' European Christmas Best Version.mpg Format : MPEG-PS File size : 4.40 GiB Duration : 1h 15mn Overall bit rate : 8 385 Kbps
    Video
    ID : 224 (0xE0) Format : MPEG Video Format version : Version 2 Format profile : Main@Main Format settings, BVOP : Yes Format settings, Matrix : Default Duration : 4s 672ms Bit rate mode : Constant Bit rate : 8 091 Kbps Width : 720 pixels Height : 480 pixels Display aspect ratio : 16:9 Frame rate : 29.970 fps Standard : NTSC Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Compression mode : Lossy Bits/(Pixel*Frame) : 0.781 Stream size : 4.47 MiB (0%)
    Audio
    ID : 128 (0x80) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Duration : 1h 15mn Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Delay relative to video : -67ms Stream size : 103 MiB (2%)
  2. AVStoDVD Author _MrC_'s Avatar
    Hi nazopo,
    first of all, I suggest you to run your ts file thru TsRemux and select only the video/audio/subs streams that you want to keep and then save to a new, smaller, ts file. Then
    1. Open AVStoDVD.
    2. Go to 'Preferences'/'Audio' and toggle off 'Keep AC3/DTS/MP2 DVD Compliant Audio'. Press OK.
    3. Add the new ts file to AVStoDVD.
    4. Go to 'Edit Title'/'AviSynth', toggle off 'Auto AviSynth Script'
    5. Click on 'Delay Audio' and enter "-831" (without quot marks, of course). Press OK.
    6. Start the project
    That's should fix your issue, assuming that the audio stream you want is the first one (ID : 69 (0x45) from your post) and MediaInfo has correctly detected the audio delay (-831ms from your post).
    Bye
    MrC
    AVStoDVD Homepage
    In TSremux, I am getting an error saying "Object reference not set to an instance of an object" whenever I try adding the .ts file to TSremux. Do you know what I should do? I am running Windows Vista SP2.
    It worked! Thank You Mr. C!
