Hi. Iīm trying to convert a 23.976 fps .avi file to a compliant DVD disc that can be played on the standalone player. The problem is that the player wonīt play the resulted DVD in any way. Iīm using TMPGenc 720x480, video format NTSC and tried fps: 29.97, pure 23.976, 23.976 with 3:2 Pulldown (within TMPGenc or external Pulldown.exe), 23.976 with 3:2 Pulldown filter (TMPGenc). The player keeps saying "incompatible disc".
Note: when doing this same conversion with ConvertxToDVD it plays fine. The problem is that I want to use VDub frameserving to TMPGenc so I can apply a sharpening filter. ConvertxToDVD donīt have this capability.
Sample .avi attached.
Thanks is advance.
Convertxtodvd authors the disc - tmpgenc is an encoder and does not author to DVD.
If you want to author a DVD: Create the avi as you are doing, run the final result through convertxtodvd (I use TDA3 to author, but if you already have convertxtodvd - why not use it?);/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
Thatīs what I wanted to do in the first place, but like I said, ConvertXToDVD doesnīt accept frameserving from VirtualDub, and I canīt create a huge temp .avi file in VDub cause I donīt have enough HD space.
Convert with tmpgenc. Use simple dvd creator to author the mpg to a standard dvd-video. Burn the VIDEO_TS folder with imgburn.
Converted HD wmv to avi but won't get sound in media player device
By Moth Queen in forum Video ConversionReplies: 2Last Post: 20th Jul 2011, 17:24 -
iTunes won't play converted files
By mez2 in forum ffmpegX general discussionReplies: 1Last Post: 12th Feb 2010, 12:50 -
AVI file won't play via stand alone DVD player
By 3lutz3toe in forum MacReplies: 2Last Post: 24th Dec 2009, 05:37 -
Neuview player won't play .AVI videos
By sic in forum Software PlayingReplies: 9Last Post: 16th Oct 2007, 13:01 -
Cannot play Avi files converted to DVD on my DVD player.
By callmejr2 in forum Newbie / General discussionsReplies: 3Last Post: 9th May 2007, 10:19
