Hello,
I have about 20-30 music videos and everytime I burn them some work and some have choppy sound.
Then I go into Virtual dub and get file information and find out if it is an vcd or not.
But sometimes the bitrate is like 1159 instead of 1150,, does this make that big of a difference?
Basically I am looking for a software where you just load your files and it tells you which ones are ntsc vcd, pal vcd, svcd etc....
Does anyone know of a software that will give quick info kinda like "avinfo" where you just right click on the file and it will give you a vcd information option or sumtin like that.
It is a pain going into virtualdub all the time.
Thanks much I appreciate any help - Tfp
Use tmpeg demux, you don't actually do it.
but it does tell you what is in the streams
vcd compress software
By akakiami in forum Authoring (VCD/SVCD)Replies: 12Last Post: 5th Sep 2008, 16:24 -
Is there any free VCD playing software which meets my requirement?
By csh in forum Software PlayingReplies: 11Last Post: 20th Dec 2007, 01:21 -
free software for adding voice through mic to vcd
By andreytenov in forum EditingReplies: 4Last Post: 12th Nov 2007, 03:20 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
post checks
By Mr anderson in forum ComputerReplies: 9Last Post: 10th May 2007, 17:36
Statistics
Newest guides
Latest tool updates
New media comments
