    Hi there.
    I'm not sure I'm in the right section, anyway :
    I've never had any problem muxing my MKV files until I downloaded the 4.4.0 version of MKVmerge recently.
    I tried muxing some files (video/subtitle/2 audio tracks) and it wasn't playing on KMplayer.
    It was playing on VLC 1.1.5 and SPlayer 3.6 though...
    In KMplayer, I had to go to the preference (F2), "Filter control", "Splitter" and then change "Matroska" to "Gabest MKV splitter" or "System Default"
    I did a couple of MKVs this way, trying to change options as much as I can, but same problem as before...
    Why can't I play my files on KMplayer ? Has anyone had the same problem ?
    Maybe because of compressed headers that newer version of mkvtoolnix uses. You can disable it in mkvmergegui when you mux.
    I gonna need some help here, what's a compressed header ? How can it be disabled in mkvmerge ? I don't see any option...
    And, what does a compressed header do ?
    In mkvmergeui select each track and under extra options set the compressed to None.
    You could also use mkvtoolnix 3.4.0 and this wont be a problem
