    Dec 2005
    Canada
    I surch to convert .exp to avi
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    I have never seen or heard of a movie file with the .exp suffix. What makes you think it is a movie file? Where did you get it (online or from some app)? What size is it?
    If you can, try to get the first ~32 bytes in hexdump. Usually files of a certain kind start with the same bytes, which may be a last resort to identify them. (E.g. AVI files start with "RIFF....AVI LIST".)
    Dec 2005
    Canada
    This file is issue from a camera systeme (surveillance camera)
