i need to convert MKV files to any format (playable on PS3), i use Format factory, MKV2VOB and lately ConvertXToDVD when i convert my files using these programs i lose all the subtitle attributes such as colour, font and the most annoying part is the positions. main dialog, titles and songs are all mixed together. what i need is something to convert MKV files w/o losing any of the subtitle attributes and please execuse my english.
You must hard code the subs into the image. Avidemux, virtualdub and avisynth with vobsub plugin supports ssa/ass with styles. And nope, it's not as easy as the tools you mentions.
i would be really grateful if you write the steps Baldrick, and where to put the plugins exactly
i read few guides about the programs you listed and i have to say i got no idea
, so i tried things myself.
okay this is what i did, i extracted Vobsub into Avidemux plugin and when i load the MKV file through Avidemux this pop first.
i pressed yes and i changed few things.
i extracted the subtitle using MKV ExtractGui and put it here (vobsub plugin) and i pressed close
i saved the file as "kk.avi" and it took a while for the converting process.
the avi file came out with no subtitle at all, so i thought its better to use virtualdub now and this is what happens when i load the avi file
please tell me what did i do wrong -
i download this
http://www.free-codecs.com/Nic_XviD_Codec_download.htm
and the virtualdub error message disappeared, but the program is really complicated what should i do from here -
okay i tried to use it but it didn't came out well
, the clip just came out fine but the sub came out with small letters, deferent font and in the middle of the screen not where it supose to be.
okay Avidemux is splendid piece of work but only for those who knows how to run it correctly, i solved all my problems with it beside one last thing. when i finish converting and hard coding i get problems with sync video/audio thing, i'm suppose to change the fram rate under Audio but to what exactly? how do i figure out the correct fram rate for every clip?
[Conversion] MKV with Multiple Audio and Subtitle streams for PS3
By SharanQ in forum Video ConversionReplies: 5Last Post: 23rd Jan 2011, 21:23 -
MKV to AVI - can you convert without losing quality?
By OM2 in forum Newbie / General discussionsReplies: 4Last Post: 12th Nov 2010, 07:52 -
mkv to mp4(ps3) subtitle issues
By HeroSmero in forum Video ConversionReplies: 2Last Post: 3rd Jan 2010, 19:43 -
How to convert mkv to ps3 viewable format maintaining mkv subs in new file?
By shuyinliquid in forum Video ConversionReplies: 2Last Post: 14th Dec 2009, 01:17 -
How Can I Convert .mkv files to any formart playable on normal DVD or PS3?
By shuyinliquid in forum Newbie / General discussionsReplies: 5Last Post: 20th Sep 2009, 12:27
