Hi! I have a DVDs with Vob files on it. I was able to copy 4 files while I couldn't rip one of the files onto my computer. What could the problem be? Can Handbrake solve this or are there any other free softwares for mac? Any advice? Thanks.
Are these commercial discs, or ones that you (or someone else) has burned ?
For commercial discs there seems to be only one recommended Mac solution - Mac The Ripper.
For burned discs you should be able to simply copy the contents to your desktop or another folder, as there will be no copy protection. If you cannot do this then you may have issues with the disc, in which case you need to look at data recovery tools instead.Read my blog here.
These are recorded by someone and given to me. I was able to rip few of the files but one file wasn't working. May be its damaged. Thanks for your help.
Free program to join vob files with dts audio
By shans in forum Newbie / General discussionsReplies: 3Last Post: 11th Apr 2013, 07:50 -
Importing VOB files--iMovie, Final Cut Express? New to Mac
By Theresa in forum MacReplies: 14Last Post: 7th Apr 2009, 09:54 -
How to Shrink 7.7 GB VOB files to 4.7GB DVD on MAC?
By mc80 in forum MacReplies: 5Last Post: 30th Mar 2008, 10:41 -
converted vob files play on computer fine..skip when burned to dvd
By cduval04 in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2007, 19:26 -
trying to convert VOB TV files into something usable on my computer
By sipapu in forum Video ConversionReplies: 5Last Post: 27th Jun 2007, 12:49
