I was wondering if there was any way to convert subtitles in mkv's without having to work on every single file individually. Currently I have to:
-open each file with mkvextractgui,
-choose track 4(subtitle track),
-press extract,
-open up subtitle conversion utility and convert it to srt.
-use rename utility to delete the "_track4" appended to the name
I dont really need to merge it back into the file but it is frustrating to have to do those steps for the hundreds of files I have. SRT's are the only universally used subtitle format for many media players (and specifically android) so I was wondering if anyone set up a more efficient system. Thanks.
Hi! i am having the same issue, and i have found MKVcleave and all my output files are empty. I was wondering if there was a way for someone to write a batch file that could read the files in a fold then extract all of the subtitles from the mkv files. I found one once but can't seem to find the same link anymore. Some times i wish the internet wasn't so fluid >.< But i digress.
I have all of the proper utility programs. And have converted all of the Mkv's to Avi All i need is the subs from the mkv's -
Try mkvcleaver 5.01,i found 5.02 wasn't extracting any srts.
Thanks johns0! I was looking for an MKV batch extractor and MKVcleaver is really, really great!
How to remove embedded subtitles from mkv
By imars99 in forum SubtitleReplies: 9Last Post: 24th Aug 2011, 02:06 -
MKV embedded subtitles don't always load in MPC-HC
By aer in forum Software PlayingReplies: 0Last Post: 22nd Aug 2011, 18:53 -
A reliable method to convert MKV to MP4
By Alphonse55 in forum MacReplies: 7Last Post: 18th Feb 2010, 20:32 -
Turining off the subtitles for mkv files in a batch
By Wolverene in forum Newbie / General discussionsReplies: 6Last Post: 7th Oct 2007, 10:09
