I am trying to convert my DVD library to MP4 to use with my Xbox 360 as a media center. Anywazzz... I am using Mpeg Streamclip to export my VOBs to MP4. Some of the exported MP4 get stuck on a frame yet the audio continues. For instance i just exported "Lost Highway" to MP4 and at 00:48:13 the video freezes, the audio keeps going but the frame is frozen. Then at 01:36:26 the video unfreezes and jumps to the correct frame with audio in sync. WTF?
When I open the VOBs I open I am asked if I want open "All Files"? I click yes to open all the VOBs.
Then Im prompted to "Fix time code breaks" and I click OK.
Then Im prompted with "This command will find and fix time code breaks in the stream" with a check box "Do not skip any frame (should not be enabled when joining files)" so I UNcheck that.
And my entire video is now open in Mpeg Streamclip.
I Export to MP4 with pretty much the default settings (H.264, AAC) The only changes I make Is I bump the quality to 100% and limit the data rate to 2000.
Any idea why this would be happening? It doent happen on all of my DVDs just some (like 50%).
Just incase anyone is concerned I own ALL the DVDs I am converting.
Thanks!
Results 1 to 1 of 1
MPEG Streamclip issue
By low-fat-al in forum EditingReplies: 2Last Post: 19th Oct 2011, 15:36 -
MPEG Streamclip won't open mp4, solutions or alt programs?
By SkyWolfAlpha in forum MacReplies: 13Last Post: 6th Mar 2011, 05:14 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
MPEG Streamclip HDV to MP4
By Mosaiikki in forum Video ConversionReplies: 1Last Post: 1st Mar 2010, 07:02 -
How to convert video to iPod MP4 using MPEG StreamClip (free)
By Baldrick in forum User guidesReplies: 20Last Post: 6th Jun 2008, 22:48
