Hello friends,
I have a movie which is m2ts x2.64 and is bluray rip
I added subtitle and made it bluray disk using tsmuxer and wrote on a DVD using Image burner.
It plays well and no problem it shows the subtitle (thanks to this site with all the helps )
( I have Windows 7 and Installed MPC HC v1.3.1249.0, CoreAVC, and Haali splitter on my system)
Problem:
Now when I put the same DVD on windows XP which I'v Installed all mentioned S/W, it doesn't show subtitle, in turn when I play it with MPC HC and right click on screen the subtitle option is gray(inactive).
so what you think the problem is?
Thread: Subtitle not working in MPC HC
Hi, Thanks Jagobo,
yes as you told now subtitle is working well and is active. once again thans
now...
The video audio is not synchronized!!! I don't Know should I ask the question here or no, but i'll be thankful if u could helpLast edited by majid_aryaee; 13th Oct 2010 at 08:34.
Audio sync: View -> Options -> Internal Filters -> Audio Switcher -> Audio Time Shift
You can also map keys for interactive adjustment while playing. -
its not constants shift in time, some part there are no problem and after sometimes playing the sound and video goes out of sync and again after sometimes ok and keep going
should i install any other codec?
thanks -
That sounds like a problem with your source, not the player.
As I told you the Same Disk playing well on my system, but not in windows xp
[Ask] MPC Stopped Working At every start
By darkw1zard in forum Software PlayingReplies: 3Last Post: 28th Nov 2012, 09:06 -
Subtitle help with VLC and MPC using DVD and external subtitle
By enigmakid in forum SubtitleReplies: 2Last Post: 2nd Feb 2012, 00:48 -
Cyberlink filters for playback in MPC - not working
By menkatek in forum Newbie / General discussionsReplies: 1Last Post: 6th Apr 2011, 04:13 -
MPC-HC subtitle default
By cheerful in forum Software PlayingReplies: 0Last Post: 30th Oct 2010, 14:27 -
Subtitle for mts playback in MPC-HC
By cheerful in forum Software PlayingReplies: 1Last Post: 24th Feb 2010, 08:35
