Hello, dear all.
I have one file in *.swf extension.
---> http://en.wikipedia.org/wiki/Swf
I can open it using MPC or similar players. But, I have some problems to save /capture frames or static images using that programs.
If I use Virtualdub ( for avi files) or MPC ( for avi files too) I can save frames /pictures from them.
But with *.swf I got issues. :C
Can you point me some tips to do what I trying to get?
Thanks.
Hi...
I google it about my question and could found out that some programs can handle what I want: some flash decompilers.
I could use one of them in trial mode ( before buy it ) and could do what I need.
My tested program was: SWF Decompiler Magic
---> www.flashdecompiler.us ( this one works for me)
I could find some other like this: SWF Decompile Expert, SWF Decompiler PremiumT and one freeware option: SWF Extractor Free
---> http://www.opendb.net/element/157.php#swf-extractor-free ( this one doesn't work for me - try it for your personal tests and needs )
---> http://www.opendb.net/category/26.php#SWF+Decompilers+%2F+SWF+Extractors
Thanks.Last edited by devilcoelhodog; 13th Oct 2010 at 15:13.
I think swftools is older than those all, and it's always been freeware.
Hello.
Nice to know !!! :P
http://www.swftools.org/ ( swftools )
In my case, SWFExtract will fit my needs. :P
I'll test it and let my results.
Thanks for the tip.
Best regards.
devil (johner)
Another free one...
SWF Extractor v1.1
EDIT: Sorry, already posted. That's the one I have. It won't do newer advanced SWF.
Sothink SWF Decompiler for advanced SWF with objects. Expensive though. $79.99
http://www.sothink.com/product/flashdecompiler/
It breaks Flash down into its component parts, including sound, images, fonts, buttons, and action scripts. 30 day free trial. You won't find anything like this or the swf decompiler magic for free.Last edited by DarrellS; 14th Oct 2010 at 03:05.
By Toastie in forum ComputerReplies: 2Last Post: 19th Aug 2013, 00:00 -
VirtualDub commandline - AVS to BMP/PNG/JPG
By wiseant in forum Video ConversionReplies: 0Last Post: 10th Mar 2012, 17:01 -
Adding Bmp/Jpg to Flav
By Soixante in forum EditingReplies: 0Last Post: 11th Jan 2010, 14:54 -
DVD Flick importing jpg/bmp
By Soixante in forum Authoring (DVD)Replies: 2Last Post: 19th Sep 2009, 14:19 -
Making an avi from jpg, bmp or png files
By cabs46 in forum Newbie / General discussionsReplies: 3Last Post: 14th Jan 2009, 06:14
