Recently i bought a Vado HD. I could transfer files into Mac Book Pro directly by copying. When i try to import the Vado HD file into FCP then the file is not seen in the preview and it says NO CODEC found. How do i edit Vado HD files in FCP and get a best quality output from the edited version. Pls help. Thanks in adavance.
regards,
Vansep
Instead of copying files, have you tried to let FCP import (File > Log and Capture) the footage directly from the camera?
You should be using the included Vado Central software to encode to MP4, which then unfortunately*
can be imported and then transcoded again into DV Stream for FCP.
From website:
Vado Central
Vado Central is a simple, easy-to-use video editing software that lets you
- preview video clips.
- transfer files to your Mac.
- convert videos to MP4 format for use in iMovie®.
- edit videos via iMovie, or using built-in Movie Creator software.
- upload videos/photos to various social media sites.
( *to avoid the quality hit you'll get importing into FCP)
or use the Vado Central software to try and export it (if possible) to
DV Stream, which FCP favors for editing."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
Buy Which camera to edit with Final cut pro with no file conversion
By rossangelo in forum MacReplies: 4Last Post: 7th Apr 2011, 17:24 -
Final Cut Express and Vado HD (Info)
By andy_elvis in forum MacReplies: 1Last Post: 6th May 2009, 08:38 -
HELP! DVCPRO50 853x480 clips edit in Final Cut Pro?
By nato17 in forum MacReplies: 2Last Post: 16th Jan 2008, 22:49 -
By nato17 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 16th Jan 2008, 22:44 -
VOBs convert to what? to edit in final cut pro...
By tSu in forum EditingReplies: 4Last Post: 16th Nov 2007, 22:07
