    I have some FCP DVCPRO HD .MOVs that I need to work with on my PC. I'm visiting a friend with FCP to convert them, so I'd like any advice on what the best comparable exporting option would be.
    In other words, I'm hoping for some FCP users to tell me what to export it as, so I'm not dumb struck by the different options when I'm front of it. Ideally, the highest quality I can get is what I want, as long as it will play on a PC since these are the only raw files now. Here's the video info:
    Complete name : I:\BTS"BEN\BTS\0002IK.mov
    Format : MPEG-4
    Format_Commercial_IfAny : DVCPRO HD
    Format profile : QuickTime
    Codec ID : qt
    File size : 3.73 GiB
    Duration : 10mn 52s
    Overall bit rate : 49.2 Mbps
    Encoded date : UTC 2010-07-23 09:28:05
    Tagged date : UTC 2010-07-23 09:28:05
    Writing library : Apple QuickTime
    Original source medium : NO NAME 1
    com.panasonic.professionalplugin : 2010-07-16 07:59:53 -0700
    com.apple.proapps.reel : NO NAME 1
    org.smpte.mxf.identification.fil : 2010-07-16 23:49:01 +0000
    org.smpte.mxf.identification.app : 0x060E2B34040101090E0E010101000001
    org.smpte.mxf.package.material.p : 0002IK
    com.panasonic.professionalplugin : 2010-07-16 07:49:01 -0700
    org.smpte.mxf.package.material.p : 0x060A2B340101010501010D4313000000F0399C98935305CE 008045822CB5D2C5
    org.smpte.mxf.package.material.p : 2010-07-16 23:49:01 +0000
    com.panasonic.professionalplugin : SHOOTING
    org.smpte.mxf.identification.app : 2.0
    com.panasonic.professionalplugin : Panasonic
    org.smpte.mxf.identification.app : Panasonic
    com.panasonic.professionalplugin : AG-HVX200
    com.panasonic.professionalplugin : E6NC00051
    com.panasonic.professionalplugin : 060A2B340101010501010D4313000000F0399C98935305CE00 8045822CB5D2C5
    com.apple.proapps.originalFormat : DVCPRO HD 720p60
    org.smpte.mxf.identification.app : P2
    org.smpte.mxf.package.material.c : 2010-07-16 23:49:01 +0000
    org.smpte.mxf.identification.gen : 0x1E4F527468974E38B7FB8BE6B79F34CC
    com.apple.proapps.clipID : 060A2B340101010501010D4313000000F0399C98935305CE00 8045822CB5D2C5
    Media/UUID : F44D732F-B7B5-4BC1-B8B7-3DE09DBF84C7
  2. Member edDV's Avatar
    Which programs on the PC? Later versions of AVID and Premiere Pro support DVCProHD P2 MXF format. Also Grass Valley's Edius. Vegas Pro needs Raylight to handle P2 media.
    ftp://ftp.panasonic.com/pub/Panasonic/Drivers/PBTS/papers/WP_P2Workflow_Vegas.Raylight.pdf
    The whole point of the Material Exchange Format (MFX file) is to allow cross platform asset flow but progress is slow. Currently P2 card MXF assets and XDCAM MXF seem to be separate worlds.
    http://en.wikipedia.org/wiki/Material_Exchange_Format
    http://www.kiva.org/about
    It was originally P2 MXF. but was then converted to the MAC Quicktime version and will not play correctly, whereas I usually can play files straight from the P2 cards.
    I've been told it would need to be converted to something else to play on PC, so I'm trying to find out what that best export option would be in FCP, in terms of quality.
  4. Member edDV's Avatar
    I haven't moved P2 MXF in that direction. It is my understanding FCP can export to P2 MXF which is the common format. There may be other ways.
    That would be fine. I wonder if exporting back to P2 MXF would return it to a PC friendly format and un-MAC-quicktime it, for severe lack of a better term?
  6. Member edDV's Avatar
    As long as the editor on the PC side can accept P2 MXF. From there you can convert to other PC friendly formats.
    Thanks for the help.
