I've been using SUPER, but since trying anything with more than 2 channels, if conversion succeeds, I end with only the two back channels, or no sound at all, or a failure. Is there a tool that can extract one audio stream, one video stream, and downconvert the audio to 2 channels from mkv to mp4?
Hi
To make a file that contains the video track and the one audio track use MKVMergeGUI (mmg) from here:-http://www.bunkus.org/videotools/mkvtoolnix/docs.html
Then use MediaInfo to show us what's in your new file. -
General
Complete name : file.mkv
Format : Matroska
File size : 297 MiB
Duration : 24mn 20s
Overall bit rate : 1 707 Kbps
Encoded date : UTC 2010-09-15 02:45:40
Writing application : mkvmerge v4.3.0 ('Escape from the Island') built on Sep 5 2010 10:30:51
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Video
Format : AVC
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 16 frames
Muxing mode : Container profile=Unknown@5.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 24mn 21s
Nominal bit rate : 1 438 Kbps
Width : 768 pixels
Height : 432 pixels
Display aspect ratio : 16:9
Frame rate : 30.000 fps
Original frame rate : 29.068 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.144
Writing library : x264 core 56 svn-667C
Encoding settings : cabac=1 / ref=16 / deblock=1:-2:-2 / analyse=0x3:0x133 / me=umh / subme=7 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=6 / nr=0 / decimate=0 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=1438 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=12 / qpmax=22 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : A_AAC
Duration : 24mn 20s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHzLast edited by planetofthemage; 11th Jun 2022 at 01:47.
converting mpeg into multi channel audio
By markdueck in forum Newbie / General discussionsReplies: 0Last Post: 5th Jun 2011, 16:35 -
Converting .MP$ with 6 channel audio to DVD
By Mongo617 in forum Video ConversionReplies: 1Last Post: 13th Jan 2011, 17:28 -
How to select audio channel when converting MKV files ?
By vcd_user in forum Video ConversionReplies: 1Last Post: 23rd Aug 2010, 16:48 -
2 audio streams converting VOB 2 MPG
By Harleyman in forum SVCD2DVD & VOB2MPGReplies: 14Last Post: 26th Sep 2009, 05:13 -
converting from Real Audio to iPOD format
By tigermoon0 in forum ffmpegX general discussionReplies: 0Last Post: 15th Aug 2007, 02:49
