Is there other HD format besides of the AVCHD and H.264 formats to burn the HD DVD?
Be careful when you use the term "HD DVD" which is a defunt , no longer supported standard (like VHS and betamax)
http://en.wikipedia.org/wiki/Hd_dvd
If you were referring to HD content on DVD5 media , you can use h.264, MPEG2 or VC-1 compression , but not all blu-ray or AVCHD compatible players can play them (as mentioned in previous discussions) -
Yes, but MPEG2 can be HD as well. MPEG2 is a type of compression
"HD" refers to the frame size > 576 height. Many retail blu-ray still use HD MPEG2 compression . You can make a "psuedo AVCHD disc" on DVD5 media using MPEG2 compression. (I say "pseudo" because AVCHD is supposed to be AVC, otherwise it would be called MPEG2HD or something... I guess) . MPEG2 compression is usually a lot worse than AVC compression in general , so usually lower quality at equivalent bitrates (it can vary on the quality of the encoder, for example some AVC encoders are very very bad)
Since "HD" only refers to the dimensions , you can use different types of compression for HD , i.e. AVC, MPEG2, VC-1 (h.264 and AVC are equivalent terms for the same type of compression)
DVD5 refers to the media. Just like DVD9 would be dual layer DVD media , or BD25 single layer blu-ray disc, BD50 is dual layer -
If you watch ATSC HD broadcast or cable in North America, it is all MPeg2. Sat uses MPeg2 or proprietary MPeg4 formats but you never see the file. Mpeg2 is also high quality, just needs more bit rate vs. h/264. Most hobbiest types trying to compress to the max will use h.264. Broadcasters and program producers use Mpeg2 or other lower compressed formats to maintrain quality through multiple generations of processing.
Blu-Ray accepts MPeg2, h.264 or VC-1 on BD/BE media. DVDR media "AVCHD" structure discs are optional for players and usually are bit rate constrained vs BD/BE. The DVDR disc can only spin so fast. DVDR "AVCHD" structure discs also can use MPeg2, h.264 or VC-1 formats in an m2ts transport stream.Last edited by edDV; 3rd Sep 2010 at 18:19.
http://www.kiva.org/about -
Yeah. I was pushing a Blu-Ray player to the limit ~30 Mb/s and it wouldn't spin DVDR any faster. I read elsewhere that early players only went to 16 Mb/s and couldn't do 24 Mb/s AVCHD with DVDR. So I guess this depends on the mechanical design of the player. BD/BE media don't need to spin as fast.
Any other than Blu-ray DVD player in the market supporting AVCHD format?
By coody in forum DVD & Blu-ray PlayersReplies: 1Last Post: 16th Aug 2010, 11:41 -
software to batch convert m2ts format avchd to mts avchd?
By masterpug in forum Video ConversionReplies: 0Last Post: 14th Aug 2010, 01:06 -
How can I edit (cut) segments from a H264 AVCHD video without re-rendering?
By kmmoore in forum EditingReplies: 5Last Post: 14th Dec 2008, 12:51 -
H264: Are there other h264 (AVCHD/VC-1) encoding command-line/CLI tools ??
By vhelp in forum Newbie / General discussionsReplies: 12Last Post: 16th Feb 2008, 01:20 -
H264 (AVCHD) OR HDV Camcorder ?
By Zetti in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 27th Dec 2007, 08:24
