    Hello.
    I was wondering if it would be possible to use another program, in conjunction with DVD Decryptor, to remove some of the newer dvd encryption protections?
    You know, like a program to decode the protection, which then could be sent to DVD Decryptor to rip to the HD...
    BTW - I've read through the stickies.
  2. VH Wanderer Ai Haibara's Avatar
    AnyDVD? DVDFab has a similar product, but I can't remember the name of it at the moment. For now, it's free while it's in beta.
    (Edit: It's DVDFab Passkey. But why not use, say, DVDFab rather than DVD Decrypter for ripping? I'm not saying you have to get rid of DVD Decrypter.)
  3. Take a look at DVDFab . . . . DVD Decrypter hasn't been updated in a long time and won't be. (Incorrect: The developer went to work for Nero on its Recode program. Should have cited DVDShrink, as pointed out in later e-mail.)
    And, although it won't be updated, either, RipIt4Me still handles an amazingly large number of conversions, although the newer encryptions sometimes (but not always) thwart it.
    Bottom line: You can benefit from having several tools available.
    Any free alternatives, besides the 'RipIt4Me'?
    I'll check out the DVDFabPasskey, even though it's a trial.
  5. DVD Fab has a freeware version. Use it to remove copy protection (to a folder on your HD), then feed those files into DVD Shrink if you're trying to reduce a DL disc to a SL disc.
  6. VH Wanderer Ai Haibara's Avatar
    Originally Posted by CobraPilot View Post
    DVD Decrypter hasn't been updated in a long time and won't be. (The developer went to work for Nero on its Recode program.)
    You're thinking of DVD Shrink's author. DVD Decrypter's author, Lightning UK, has since created Imgburn.
  7. Ai Haibara, you are, of course, 100% correct.
    I was going to rip the dvd's chapters/episodes to the HD, and then convert them to different files formats.
    Thanks for all the help finding the right software. It saved me some time...
