Hi, If i rip a dvd movie to H264/MPEG-4 Will i get same Picture & Audio Quality of Original.? Which is the best profile that a dvd should be ripped?
Great thanx.. i tried staxRip.. Converted The Island Movie, The output is amazing & was Beyond My expectation. here is a log file i just paste...
Environment
StaxRip version: 1.1.6.0
OS Name : Windows 7 Home Premium
OS Version : 6.1.7600.0
OS Type : 64-bit
OS Culture : English (United States)
.NET
v2.0.50727 : 2.0.50727.4927
v3.0 : 3.0.30729.4926
v3.5 : 3.5.30729.4926
AviSynth Plugins
Deen, DirectShowSource, TCPDeliver, UnDot
Source file info
C:\Users\skorpinok7700\Desktop\THE_ISLAND\VIDEO_TS \VTS_02_1.VOB
General
Complete name : C:\Users\skorpinok7700\Desktop\THE_ISLAND\VIDEO_TS \VTS_02_1.VOB
Format : MPEG-PS
File size : 5.92 GiB
Duration : 1h 10mn
Overall bit rate : 12.0 Mbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Default
Format_Settings_GOP : M=3, N=15
Duration : 1h 10mn
Bit rate mode : Variable
Bit rate : 10.9 Mbps
Nominal bit rate : 7 500 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Standard : PAL
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Scan order : Top Field First
Bits/(Pixel*Frame) : 1.052
Stream size : 5.40 GiB (91%)
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Duration : 1h 10mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Video delay : -104ms
Stream size : 195 MiB (3%)
Audio #2
Format : AC-3
Format profile : Dolby Digital
Duration : 1h 10mn
Bit rate : 192 Kbps
Channel(s) : 2 channels
Stream size : 97.4 MiB (2%)
Text #1
Format : RLE
Format/Info : Run-length encoding
Text #2
Format : RLE
Text #3
Format : RLE
Text #4
Format : RLE
Text #5
Format : RLE
Menu
DGIndex - Demux audio and index MPEG-2
"C:\Users\skorpinok7700\AppData\Local\Temp\Rar$EX0 0.389\Applications\DGIndex\DGIndex.exe" -i "C:\Users\skorpinok7700\Desktop\THE_ISLAND\VIDEO_T S\VTS_02_1.VOB" -ia 2 -fo 0 -yr 1 -tn 1 -om 2 -drc 2 -dsd 0 -dsa 0 -o "C:\Users\skorpinok7700\Desktop\THE_ISLAND\VIDEO_T S\VTS_02_1 temp files\\VTS_02_1" -hide -exit
Demuxer: DGIndex - Demux audio and index MPEG-2
Start: 5:20:20 PM
End: 5:23:35 PM
Duration: 00:03:15
Source Macros
Source Directory: C:\Users\skorpinok7700\Desktop\THE_ISLAND\VIDEO_TS \VTS_02_1 temp files\
Source Directory Name: VTS_02_1 temp files
Source Directory Parent: C:\Users\skorpinok7700\Desktop\THE_ISLAND\VIDEO_TS \
Source File Path: C:\Users\skorpinok7700\Desktop\THE_ISLAND\VIDEO_TS \VTS_02_1 temp files\VTS_02_1.d2v
Source Files Blank: "C:\Users\skorpinok7700\Desktop\THE_ISLAND\VIDEO_T S\VTS_02_1 temp files\VTS_02_1.d2v"
Source Files Comma: "C:\Users\skorpinok7700\Desktop\THE_ISLAND\VIDEO_T S\VTS_02_1 temp files\VTS_02_1.d2v"
Source Framerate: 25.00
Source Frames: 195645
Source Image Height: 576
Source File Name: VTS_02_1
Source Seconds: 7826
Source Image Width: 720
AviSynth Filters
MPEG2Source("C:\Users\skorpinok7700\Desktop\THE_IS LAND\VIDEO_TS\VTS_02_1 temp files\VTS_02_1.d2v")
Crop(0,0, -Width % 8,-Height % 8)
ConvertToYV12()
Yadif()
Crop(0,80,-0,-80)
Media Info Audio Source File
General
Complete name : C:\Users\skorpinok7700\Desktop\THE_ISLAND\VIDEO_TS \VTS_02_1 temp files\VTS_02_1 T80 3_2ch 384Kbps DELAY -24ms.ac3
Format : AC-3
File size : 358 MiB
Duration : 2h 10mn
Overall bit rate : 384 Kbps
Audio
Format : AC-3
Duration : 2h 10mn
Bit rate : 384 Kbps
Stream size : 358 MiB (100%)
Audio encoding using eac3to
"C:\Users\skorpinok7700\AppData\Local\Temp\Rar$EX0 0.389\Applications\eac3to\eac3to.exe" "C:\Users\skorpinok7700\Desktop\THE_ISLAND\VIDEO_T S\VTS_02_1 temp files\VTS_02_1 T80 3_2ch 384Kbps DELAY -24ms.ac3" "C:\Users\skorpinok7700\Desktop\THE_ISLAND\VIDEO_T S\VTS_02_1 temp files\VTS_02_1 T80 3_2ch 384Kbps DELAY -24ms_AudioOutput.ac3" -448 -24ms -normalize -down6 -progressnumbers
AC3, 5.1 channels, 2:10:26, 384kbps, 48khz, dialnorm: -27dB
The Nero decoder doesn't seem to work, will use libav instead.
Removing AC3 dialog normalization...
Decoding with libav/ffmpeg...
Remapping channels...
Applying RAW/PCM delay...
Writing WAV...
Creating file "C:\Users\skorpinok7700\Desktop\THE_ISLAND\VIDEO_T S\VTS_02_1 temp files\VTS_02_1 T80 3_2ch 384Kbps DELAY -24ms_AudioOutput.ac3.pass1.wav"...
Clipping detected, a 2nd pass will be necessary.
Caution: The WAV file is bigger than 4GB.
Some WAV readers might not be able to handle this file correctly.
Starting 2nd pass...
Reading WAV...
Encoding AC3 <448kbps> with libAften...
Creating file "C:\Users\skorpinok7700\Desktop\THE_ISLAND\VIDEO_T S\VTS_02_1 temp files\VTS_02_1 T80 3_2ch 384Kbps DELAY -24ms_AudioOutput.ac3"...
The original audio track has a constant bit depth of 64 bits.
The processed audio track has a constant bit depth of 64 bits.
eac3to processing took 11 minutes, 23 seconds.
Done.
Start: 5:36:48 PM
End: 5:48:14 PM
Duration: 00:11:25
Audio Encoding Complete
Start: 5:36:48 PM
End: 5:48:14 PM
Duration: 00:11:25
Bitrate: 447.99 kbps
General
Complete name : C:\Users\skorpinok7700\Desktop\THE_ISLAND\VIDEO_TS \VTS_02_1 temp files\VTS_02_1 T80 3_2ch 384Kbps DELAY -24ms_AudioOutput.ac3
Format : AC-3
File size : 418 MiB
Duration : 2h 10mn
Overall bit rate : 448 Kbps
Audio
Format : AC-3
Duration : 2h 10mn
Bit rate : 448 Kbps
Stream size : 418 MiB (100%)
x264
"C:\Users\skorpinok7700\AppData\Local\Temp\Rar$EX0 0.389\Applications\x264\x264.exe" --crf 22 --level 4 --keyint 100 --vbv-bufsize 25000 --vbv-maxrate 20000 --sar 16:11 --output "C:\Users\skorpinok7700\Desktop\THE_ISLAND\VIDEO_T S\VTS_02_1 temp files\VTS_02_1_EncoderOutput.h264" "C:\Users\skorpinok7700\Desktop\THE_ISLAND\VIDEO_T S\VTS_02_1 temp files\VTS_02_1.avs"
avs [info]: 720x416p 16:11 @ 25/1 fps (cfr)
x264 [info]: using SAR=16/11
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2
x264 [info]: profile High, level 4.0
x264 [info]: frame I:3662 Avg QP:20.05 size: 26239
x264 [info]: frame P:105963 Avg QP:23.63 size: 9834
x264 [info]: frame B:86020 Avg QP:26.04 size: 2896
x264 [info]: consecutive B-frames: 22.7% 46.7% 18.0% 12.6%
x264 [info]: mb I I16..4: 13.6% 69.2% 17.2%
x264 [info]: mb P I16..4: 4.0% 12.4% 1.8% P16..4: 41.3% 16.3% 8.9% 0.0% 0.0% skip:15.2%
x264 [info]: mb B I16..4: 0.2% 0.5% 0.1% B16..8: 41.0% 5.4% 1.4% direct: 3.4% skip:48.0% L0:39.5% L1:50.4% BI:10.1%
x264 [info]: 8x8 transform intra:67.9% inter:73.5%
x264 [info]: coded y,uvDC,uvAC intra: 61.5% 75.4% 36.8% inter: 25.3% 31.3% 4.2%
x264 [info]: i16 v,h,dc,p: 44% 17% 9% 30%
x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 26% 13% 25% 5% 5% 8% 5% 8% 5%
x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 29% 13% 14% 6% 8% 11% 7% 8% 5%
x264 [info]: Weighted P-Frames: Y:2.6%
x264 [info]: ref P L0: 60.9% 14.9% 17.0% 6.9% 0.3%
x264 [info]: ref B L0: 79.9% 18.5% 1.6%
x264 [info]: ref B L1: 95.0% 5.0%
x264 [info]: kb/s:1418.08
encoded 195645 frames, 30.64 fps, 1418.08 kb/s
x264 Statistics
Start: 5:48:14 PM
End: 7:34:41 PM
Duration: 01:46:26
Muxing using mkvmerge
"C:\Users\skorpinok7700\AppData\Local\Temp\Rar$EX0 0.389\Applications\MKVtoolnix\mkvmerge.exe" -o "C:\Users\skorpinok7700\Desktop\THE_ISLAND\VIDEO_T S\VTS_02_1.mkv" --noaudio --nosubs --default-duration 0:25.000fps "C:\Users\skorpinok7700\Desktop\THE_ISLAND\VIDEO_T S\VTS_02_1 temp files\VTS_02_1_EncoderOutput.h264" --no-chapters --language 0:eng "C:\Users\skorpinok7700\Desktop\THE_ISLAND\VIDEO_T S\VTS_02_1 temp files\VTS_02_1 T80 3_2ch 384Kbps DELAY -24ms_AudioOutput.ac3" --ui-language en
mkvmerge v3.3.0 ('Language') built on Mar 24 2010 14:59:24
'C:\Users\skorpinok7700\Desktop\THE_ISLAND\VIDEO_T S\VTS_02_1 temp files\VTS_02_1_EncoderOutput.h264': Using the AVC/h.264 ES demultiplexer.
'C:\Users\skorpinok7700\Desktop\THE_ISLAND\VIDEO_T S\VTS_02_1 temp files\VTS_02_1 T80 3_2ch 384Kbps DELAY -24ms_AudioOutput.ac3': Using the AC3 demultiplexer.
'C:\Users\skorpinok7700\Desktop\THE_ISLAND\VIDEO_T S\VTS_02_1 temp files\VTS_02_1_EncoderOutput.h264' track 0: Extracted the aspect ratio information from the MPEG-4 layer 10 (AVC) video data and set the display dimensions to 1047/416.
'C:\Users\skorpinok7700\Desktop\THE_ISLAND\VIDEO_T S\VTS_02_1 temp files\VTS_02_1_EncoderOutput.h264' track 0: Using the MPEG-4 part 10 ES video output module.
'C:\Users\skorpinok7700\Desktop\THE_ISLAND\VIDEO_T S\VTS_02_1 temp files\VTS_02_1 T80 3_2ch 384Kbps DELAY -24ms_AudioOutput.ac3' track 0: Using the AC3 output module.
The file 'C:\Users\skorpinok7700\Desktop\THE_ISLAND\VIDEO_T S\VTS_02_1.mkv' has been opened for writing.
The cue entries (the index) are being written...
Muxing took 79 seconds.
Muxing Statistics
Start: 7:34:41 PM
End: 7:36:02 PM
Duration: 00:01:21
Job Complete
Start: 5:36:48 PM
End: 7:36:02 PM
Duration: 01:59:14
Media Info Target File
General
Complete name : C:\Users\skorpinok7700\Desktop\THE_ISLAND\VIDEO_TS \VTS_02_1.mkv
Format : Matroska
File size : 1.70 GiB
Duration : 2h 10mn
Overall bit rate : 1 868 Kbps
Encoded date : UTC 2010-08-24 15:34:43
Writing application : mkvmerge v3.3.0 ('Language') built on Mar 24 2010 14:59:24
Writing library : libebml v0.8.0 + libmatroska v0.9.0
Video
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Muxing mode : Container profile=Unknown@4.0
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 10mn
Bit rate : 1 383 Kbps
Width : 720 pixels
Height : 416 pixels
Display aspect ratio : 2.517
Original display aspect ratio : 2.518
Original frame rate : 43 690.668 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.185
Stream size : 1.26 GiB (74%)
Writing library : x264 core 93 r1542 5b86182
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / wpredp=2 / keyint=100 / keyint_min=10 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=22.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / vbv_maxrate=20000 / vbv_bufsize=25000 / crf-max=0.0 / ip_ratio=1.40 / aq=1:1.00 / nal_hrd=none
Audio
Format : AC-3
Codec ID : A_AC3
Duration : 2h 10mn
Bit rate : 448 Kbps
Stream size : 418 MiB (24%)
Language : English
MPEG Streamclip MPEG-TS to MPEG4/H264 (file size & aspect ratio query)
By Heathy65 in forum Video ConversionReplies: 5Last Post: 4th Apr 2012, 11:31 -
Movie-Only Ripping - full main movie shows up as more than one title
By ecc in forum DVD RippingReplies: 2Last Post: 9th May 2009, 01:13 -
ripping a dvd to mkv h264 filesize question
By stackner in forum DVD RippingReplies: 5Last Post: 16th Jan 2009, 17:13 -
Convert mpeg to h264
By bijoythulas in forum Video ConversionReplies: 7Last Post: 1st Oct 2008, 20:15 -
which converter for mpeg-4 h264
By jayman34 in forum Video ConversionReplies: 2Last Post: 27th Sep 2008, 08:10
