I need to create (Camera?) edit (software?) and display (Screen?) movies with 120 FPS.
Any help will be appreciated
Results 1 to 11 of 11
Do you wish to shoot at high speed and play back at normal speed? Or do you wish to shoot at normal speed and play back at high speed? Or do you wish (for some odd reason) to both shoot and play back at 120 FPS?
If you want help, you need to give us a clue about your goals. -
i wish to shot at 120 fps (or buy) edit (need to add stuff between frames => which software can break movie into frames) and play at 120fps (computer display that can play 120 fps)
Not possible. 120fps cams alone cost more than that.
You still need to be MUCH MORE CLEAR in your request/description.
Scott -
Do you mean HD high quality , or postage sized bad quality?
For example , Red One (body only) is about $18K , but more like $60-70K when you add in accessories required for shooting
For low quality , but consumer priced , you might check out Casio EX-F1 (<$1K) , it can shoot : 512 × 384 (300 fps), 432 × 192 (600 fps), 336 × 96 (1200 fps) -
What????!!!! I'm beginning to think you're confused. Are you trying to match a movie's frame rate to a monitor's refresh rate?
No commercial movie is shot at such a high frame rate, nor is any DVD or BR disc designed to play back at 120fps.
Or did I miss something? Do you want to shoot your own movies (your opening question included camera), or simply play back movies that have been already made?
You're about as clear as mud on this issue.
Create edit and display movie with 120 FPS
By uridavid in forum Newbie / General discussionsReplies: 1Last Post: 20th Aug 2010, 06:41 -
Variable frame rate (vfr) and 120 (119.88) fps video playback big problem
By lovyagin in forum Software PlayingReplies: 0Last Post: 22nd May 2009, 04:40 -
why a dvd movie's length is longer than 120 min
By hzgg2 in forum Video ConversionReplies: 5Last Post: 5th Sep 2008, 18:20 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17 -
burn 120 minutes movie in 1 CD?
By hackerzlab in forum Newbie / General discussionsReplies: 18Last Post: 9th May 2007, 10:16
