Hello (again) guys!
Sorry to bother, but I just can't get this one off my mind.
Check this out. I rtmpdump:ed some [totally legit] streams from the world wide überspace. They landed as .mp4 locally. MediaInfo tells me that the container itself is "Flash" and that they contain one AVC video stream and one AAC audio stream. So far so good. Now, I would rather like a traditional ISOM/MP4 container, so I did a simple 'mp4box -add stream.mp4 stream-fixed.mp4', which obviously wouldn't cut it. It said unknown media. I assume mp4box doesn't support Flash container for input.
Anyway, I found a solution in the [wonderful] all-around utility ffmpeg. Simply 'ffmpeg -i stream.mp4 -acodec copy -vcodec copy stream-fixed.mp4' did the trick. But here comes the strange part. When I pulled MediaInfo on this new .mp4 file, I notice "Duration_LastFrame: -20ms". What does that mean? I did some Google searching but came up empty-handed, without explanation, only a couple of random occurrences in a couple of MediaInfo dumps (where that line wasn't the headline).
Anyways, I actually prefer Matroska over all other media containers. So a "mkvmerge -o stream-fixed.mkv stream-fixed.mp4" was my final mux. Now, that weird "Duration_LastFrame: -20ms" line was omitted from the MediaInfo dump. Strange, huh? Did it have any significance at all? Just curious.
Ty in adv~
Regards~
Results 1 to 1 of 1
Drop dead gorgeous!
Avidemux multiplex using VBR MP3 "looses" ABR value according to Mediainfo
By ekred in forum Video ConversionReplies: 0Last Post: 25th Oct 2011, 06:39 -
Mediainfo File Info tool "Format Profile" wrong info problem
By dabas in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2010, 05:07 -
Setting "top field first" flag without re-encoding/re-authoring
By Miles in forum Authoring (DVD)Replies: 2Last Post: 16th Jan 2009, 06:15 -
U.K. to give new meaning to "Big Brother" is watching
By aedipuss in forum ComputerReplies: 11Last Post: 18th Oct 2008, 09:00 -
Seeking avisynth function for "blend-a-field" idea
By vhelp in forum EditingReplies: 2Last Post: 21st Sep 2008, 20:52
