How do I add .srt files ( subtitles ) to a Bluray Disk ??
Should I attach .srt files to m2ts or there is another possibility , and How ???
What soft is necessary ???
Depends what you are using to play it. You should be able to add the .srt as a stream using tsMuxer. If the player only understands PGS subs I'd check into converting to PGS. If you need to hard code it, I'd probably use BD Rebuilder Avs Filter option to burn the subs in using TextSub function. More specific answers require more specific questions.
http://milesaheadsoftware.org/
Fully enabled freeware for Windows PCs.
How do I add .srt subs to avi?
By 12 gage in forum SubtitleReplies: 16Last Post: 1st Jun 2014, 16:58 -
How to add SRT subtitles to a DVD?
By sldvd in forum Newbie / General discussionsReplies: 3Last Post: 3rd Aug 2011, 13:39 -
add SRT to VIDEO_TS
By exekutive in forum MacReplies: 8Last Post: 4th Jul 2011, 12:49 -
How To add srt onto VOB/MKV?
By LeorD in forum SubtitleReplies: 0Last Post: 1st Jan 2009, 15:17 -
How to add TWO subtitles .srt on the same DVD?
By DaPuertorican in forum ffmpegX general discussionReplies: 1Last Post: 5th Jan 2008, 13:54
