Please consider supporting us by disabling your ad blocker or buy PlayOn (record Netflix) :)
Results 1 to 26 of 26
    Apr 2003
    Hey guys!
    Having a bit of a problem sending an email using Outlook 2007. I can send an basic email, but I have tried to send an email with some photos attached approx 36mb and all it seems to do is sit in the outbox and not go anywhere, outlook says that it is trying to send but nothing seems to happen, I also tried making the attachments smaller but still nothing.
  2. Member DB83's Avatar
    Jul 2007
    From another forum (have no idea if it works):
    Click Tools >Accounts >Mail >Properties >Advanced >untick break apart messages over 60kb
    But.......
    36 meg for one mesage is far too big. The chances are that the incoming mail-server will reject the message.
    Apr 2003
    Any suggestions how I could compress the images to be able to send them?
  4. Member DB83's Avatar
    Jul 2007
    Don't compress them.
    Add the images to a zip file and upload the zip to a file hosting service such as Rapidshare or Megaupload.
    You then just send a normal email which includes the link to the file on the hosting service, which is given to you once the file has been uploaded (do not close the uploading page) and the person who receives the mail can click on the link to download the images.
    There is an even more direct method by uploading the zipfile to a service such as www.yousendit.com where you have an option of entering the email address of the person you want to send the images to. The person receives an email from yousendit and can click on the link that is enclosed in that email to receive them. The only thing I have found with yousendit is that it can be a little slow to upload/download.
    And you can create an account at Rapidshare and Yousendit for free.
  5. Dropbox is another one I like. A small client runs on your system and anything you drop in the Dropbox folder get's synced to the internet. Then you can right click the file and get it's public address to past in an email.
    There is absolutely no reason to have a 36MB image.
    High res JPEG photos that I email to editors are only 5MB in size. I'll attach up to 20MB to a single message.
    If JPEG is not good enough, put a disc in the mail, or invest in your own web space.
    Many people have started to refuse using services like yousendit, megaupload and rapidshare, because it takes too long. There is that 60-90 second wait, "server too busy" BS, and then slow downloading speeds. To "fix" this problem, they suggest you pay them lots of money. The only people really using these are "file sharers" (porn, movies, software, etc).
    I've stopped helping a lot of people here lately, because they want you to download their sample videos from rapidshare, etc. Screw that.
  7. That's why I like Dropbox. No waits, no fee for the free level of service, which gets you 2GB of storage, and it's always been fast for me without downtime. You get a direct link to the file that you paste into your email.
    Apr 2003
    Thanks for all the replys, I have actually just ried to send a text only email (5kb) and it still just sits there in the outbox.
    I checked the account setting and tried the 'test account setting' which were both sucessful.
  9. Member DB83's Avatar
    Jul 2007
    So your topic should really read "Outlook not sending email"
    I do not use Outlook. Outlook Express is much easier. And I see you are on XP so you can use that. Give it a try and come back if it still does not work.
  10. Video Restorer lordsmurf's Avatar
    Your settings are wrong, then.
  11. Try sending it in HTML format.
    One benefit to usiing Outllook is most AV software will scan incoming emails, they don't scan with Express.
  12. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    i've used a bunch of a/v (norton, macafee, avast, kapersky.....) and all scan o.e. as far as i have found.
  13. Member Cornucopia's Avatar
    Email is NOT the right tool for this job, FTP is. That's what it's meant for.
  14. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    FTP is a ridiculous suggestion to make to the average Joe.
    Apr 2003
    This morning I tried to send the same email to myself and it went straight away!
  16. Member DB83's Avatar
    Jul 2007
    Sending an email to yourself does not GO anywhere. That is to say it does not make use of your ISP, POP settings or ports.
  17. Video Restorer lordsmurf's Avatar
    Email is NOT the right tool for this job, FTP is. That's what it's meant for.Scott
    Average Joe needs to learn FTP.
    Or mail a disc.
    Or just quit, give up.
    FTP is generally easier than setting up a Facebook page.
    Yes it does. It goes to the server, then back again.
  19. Member classfour's Avatar
    The Heartland, United States
    The recipient's ISP can also prevent receipt of an email above a certain size. One local ISP limits emails to 2MB, including attachments.
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
  20. Empty your Outbox. Do a send/receive with no outgoing, verify all is OK.
    Use the Send Test Msg function. This does go out to the server and back to you.
    Send yourself an E-mail with a very small attachment.
    Next, send your intended recipient a test e-mail with a very small attachment. If this fails, test with some different recipients.
    These tests will eliminate issues other than file size.
    A 36 MB attachment is likely to be refused by either your ISP, the receiver's ISP, or simply to take so long that a problem is assumed and the process gets canceled. Failure due to large size is almost assured. Generally try to keep under 5 MB.
    A very small attachment would be a text file with the word "test" in it.
  21. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    hehe you've been around a long time to be replying to a dead 3 year old thread.
  22. Damn I've got to start looking at dates.
    I'm wondering how I found this in the first place.
  23. Member bendixG15's Avatar
    Aug 2004
    Me too, what a waste of time reading dead stuff
  24. Member p_l's Avatar
    Montreal, Canada
    The "use Megaupload" suggestion in the 4th post should have been the dead giveaway.
  25. I'm a Super Moderator johns0's Avatar
    canada
    A spammer message might of been deleted recently from this post so it looked recent.
  26. DECEASED
    Jun 2009
    Heaven
    Indeed, below is the profile page of the spammer:
    http://forum.videohelp.com/members/225131-dereckstorm
