my dat file movies in my hard disk is about 725 mb..i converted to mpg
by using vcd gear but it compressed only 9 mb..how can i compress
it?
Results 1 to 12 of 12
You can burn a 725 MB MPEG onto a 74 min CD-R easily.
http://www.vcdhelp.com/vcd.htm
http://www.vcdhelp.com/burnmpg.htm
http://forum.vcdhelp.com/search.php
a 80 min cd is 700 mb
Do it or leave it. It's your choice...
Hey gediz, are you trying to burn a data cd or a vcd? If you're trying to burn a vcd, Truman is right. 720mb will easily fit onto one cd. I use 80min/700mb cd-rs, and have easily fit close to 800mb mpgs when I make my svcds without overburning them or anything.
Yeah, it sort of seems weird, but that's just the way it is. If you would actually try it, you'd be surprised.
If this is true, then why did the Ulead program warn me about not having enough Mb to load 793mb on a 656 disk? The disk says it is 74mins @ 650Mb
I'm about to give up!
Because 793 MB doesn't fit on a 74 min disc, even in Mode2/Form2. The limit for 74 min is ~740MB, for 80 min ~800.
Will this size CDR be large enough to also write the lead in/out?
Yes
Well, I got the larger CDR and attempted to write to it and my computer didn't recognize it. I tried again to write the movie to a regular CDR and it fit, trouble was that It didn't write the lead in or out causing my Sony DVD/VCD/SVCD player to not recognize it either. What's next or what am I doing wrong? I'm using the Ulead program.
shit. i was able to burn an 822mb dat file on my disc...
For some reason, My burner didn't burn the lead in or out. I don't get it. Maybe I did something wrong.
Player needs dat. file of avi files on disk
By karadeano in forum LinuxReplies: 8Last Post: 26th Nov 2011, 16:13 -
Does recoding a 7gb mkv file require a lot of hard disk space?
By dave in or in forum Video ConversionReplies: 3Last Post: 21st Aug 2011, 17:01 -
Put mp3 audio file from hard disk to forrum post
By vitcon in forum ComputerReplies: 5Last Post: 18th Mar 2011, 11:11 -
Exporting a little movie file that won't consume my entire hard disk space
By Danny Pro in forum Video ConversionReplies: 5Last Post: 14th Feb 2010, 23:50 -
Burning iso image from Hard disk to hard disk?
By When in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 22:27
