I've been in the process of converting my home videos to mp4 using StaxRip. I don't want to have the date and time burnt in every clip.
I do have the date and time in the filename, but I'd really like to store this in the file metadata similar to a photo's EXIF taken date.
I have been trying to figure out how to do this using mp4box, but I'm stumped. I've done hundreds of searches on the web for this. I know mp4 supports xml data as well, can that be used?
What is the correct meta data field to use so that Windows 7 and other programs recognizes it as the date of the clip, and how to I store it in the mp4?
Thanks for any help.
Hi
With Linux I can use a program called AtomicParsley to set or alter mp4 metadata.
These are the 'tags' that may be used:-
--artist
--title
--album
--genre
--tracknum
--disk
--comment
--year
--lyrics
--composer
--copyright
--grouping
--artwork
--bpm
--albumArtist
--compilation
--advisory
I can't see a data field that is used for Date and Time.
The 'year' tag accepts an integer to represent a year.
I suppose that you could put the Date and Time in the 'comment' field.
AtomicParsley is a command-line program.
Google shows that there are GUIs available for Windows.
EDIT
My bad. The 'year' tag will accept a UTC value such as 2010-07-12T23:09:00.
Maybe this is what you need to use.Last edited by bat999; 12th Jul 2010 at 17:15. Reason: Added stuff about UTC.
Thanks, yes I've looked at AtomicParsley. It seems to work with metadata, but the "year" field is not enough. I have nearly 100 files taken in each year that I need to set.
Using MediaInfo I see there is an "Encoded Date" and "Tagged Date" already stored in the file which is includes time. Anyone know how to change those using MP4Box?
It looks like the "Date Taken" will need to be in the XMP. My understanding is that mp4 supports XMP and MP4Box can write to it, but I can't find any instructions of how. Any help?
hacking about with broadcast video and meta data
By transcodeJux in forum Video ConversionReplies: 0Last Post: 31st Jan 2012, 11:05 -
how to extract meta data from a DVD?
By Toastie in forum Authoring (DVD)Replies: 5Last Post: 10th Aug 2011, 23:12 -
Sony Bloggie Date Time Stamp Data Code Imprint Overlay MP4 Video
By surfandride in forum EditingReplies: 4Last Post: 30th Apr 2011, 08:03 -
Custom Blu-ray meta data
By ni9ht_5ta1k3r in forum Blu-ray RippingReplies: 1Last Post: 28th Jun 2009, 17:40 -
Best way to create a 'correct' FLV's with meta data in?
By OM2 in forum Newbie / General discussionsReplies: 0Last Post: 29th Mar 2008, 13:43
