As a Video Clip Collector, and always looking for something new on internet,
I have came across following wonderful and very illustrative guide for AVIDemux.
I would also like to share same with all of you folks.
link : http://www.ahashare.com/torrents-details.php?id=74788
The Guide is in detail - a step-by-step, very easy to follow, and
it includes sample video(s) to make your own clip(s).
Finally, many thanks to the uploader.
Results 1 to 15 of 15
Initially I was tempted to modify the contents and upload here.
Later I decided to just post a link.
updates from comments:
DIRECT DOWNLOAD LINK:
http://www.mediafire.com/file/myzdqmmgloh/How to Make Video Clip.zip -
Thanks, but the Mediafire link doesn't work.
It does work.
You just need to select, copy all the text and paste on the address bar. If you just click the first part of the link it won't direct you to the right place, cause the spaces on the file name are not recognized and you just click on it. -
but you'll need an mediafire account to save the 63mb (?) file...otherwise, just the page's URL is saved
Author, Producer, Composer, Director - Sony HDV, Konica SLR, LG BD burner
Handcoder: HTML, PHP, JS, CSS - In Production: Busker Alley - The Movie -
No way.
I don't have an account and I downloaded it.
Don't try to use a download manager. -
i hv downloaded successfully by above link too!
alternatively one may try any of following links"
-or-
http://www.mediafire.com/?myzdqmmgloh
-or-
http://download945.mediafire.com/jzm94nkldtkg/myzdqmmgloh/How+to+Make+Video+Clip.zip
hope, these should be fine. -
Put in the URL tags yourself and make a correct clickable link:
Thanks got it. Had to use Opera rather than Firefox.
How to get started with avidemux, edit and convert any video format
A guide by Baldrick
link : http://tinyurl.com/2uakxr9
AVIDemux Rocks! -
I like what I've seen of AVIDemux so far, but when it comes to clip extraction, DVD SHRINK still excels at this, and it is hard to imagine how anything else could be easier.
Open the DVD or VIDEO_TS folder (if already ripped) -->
ReAuthor Mode -->
Set the Start and End markers [ ] -- conveniently time-based.
And that's about it.
There probably are some DVDs Shrink can't open, but I've extracted a great many clips directly from un-ripped titles, without the protections interfering at all. The failure rate has been negligible.
One thing I haven't done -- because I mostly deal with material in DVD format -- is try to extract clips from single, downloaded video files. If I should have occasion to do that, perhaps AVIDemux will be a major discovery.When in Las Vegas, don't miss the Pinball Hall of Fame Museum http://www.pinballmuseum.org/ -- over 150 tables from 6+ decades of this gradually disappearing American art form. -
@ Seeker47
DVDShrink, definitely, i wud consider as best VOB extractor or Chapter Grabber tool, which in turn gives you 100% quality in uncompressed mode.
But editing features are limited as if one wants just the middle part of particular segment. Or joi two different parts.
further more documentation is lmited, which makes bit difficult for a newbies. -
I have tried AVIDemux with different video format flv, mp4, wmv, mpg, mkv ...most of the time AVIDemux is able to import video and generate the index for further editing successfully.
It is always better to open a video file of any format directly in AVIDemux, if AVIDemux fails to open it, it is better to convert it to AVI format by maintaining same Video + Audio bit rates. -
Converting FLV / MP4 Files to DVD Playable Standalone
AVIDemux CONVERTED VIDEO (AVI FOR DVD)
FILTERS USED
1) ReSize : 720x400 (16:9)
2) aSharpen FILTER with HQ Mode [v] Checked
Follow This Post : Converting FLV / MP4 Files to DVD Playable Standalone
At last, use either DVDFlick or Convertx2DVD for converting AVI files to stand-alone DVD -
INTERNET VIDEO DOWN-LOADER
You can try any from HERE, and stick to the one that gives you best quality.
MP4 TO AVI CONVERTER
Once you already downloaded HD video...
for those who has difficulties with AVIDemux can use this FreeMP4-2-AVIConverter.
Profile Settings:
Video Encoder : XViD
Frame Rate : 29.97 -OR- AUTO [BETTER]
Video Sise : 640x360
BitRate : 2000 or whatever you like
Additional Command Line Parameter : -aspect 16:9
Audio Encoder : Lame 3.98
Audio Channel : 2
Audio Sampling Freq : 48000
Audio Bitrate : 320
MP4 TO MAKE DVD FOR STANDALONE DVD PLAYER
You may wish to use this tool or this one.
1) Download 1920x1080 or 1280x720 HD videos.
2) Convert all videos to XViD (AVI), load profile.
3) Make DVD by using DVDFlick, AVI2Iso or ConvertX2DVD.Last edited by Bonie81; 21st Oct 2010 at 07:12.
Avidemux aspect ratio question [from newbie to Avidemux]
By ANOther1676 in forum EditingReplies: 1Last Post: 20th Jan 2012, 20:07 -
[AVIDEMUX] How to make a new file?
By lidl in forum EditingReplies: 1Last Post: 23rd Nov 2009, 08:47 -
How to make a short animated movie/video clip? Example included.
By UmmAddan in forum Newbie / General discussionsReplies: 1Last Post: 3rd Feb 2009, 09:36 -
How to make your own guide
By Baldrick in forum User guidesReplies: 4Last Post: 6th May 2008, 10:58 -
How to make a short clip?
By kenzo69 in forum ffmpegX general discussionReplies: 2Last Post: 18th May 2007, 19:15
