I am wanting to convert some MKV files I have (they are 720p, 1.45 GB each) to AVI files that are around 5-600 MB. Is it possible for me to do this, also I have been using the program Format Factory to do this.
Yep. Format factory can do that. Lower the bitrate for lower file size.
It's not likely he can reduce the bitrate to 1/3 of the source and keep the frame size without serious degradation of quality. Of course, it depends on the nature of the video and codecs used.
Understood. Just wanted to state the obvious first. Also it depends on the screen size as I mentioned. Hd isn't needed for most portable devices but if its for tv viewing than you have decide if smaller file size is worth it to lose the resolution upon conversion.
Also it is likely the user is trying to convert the mkv so it can be played on a device that can't do mkv natively. If so they should try something like mkv2vob if they have a ps3. Of course STREAMING would probably be best if the tv is the destination and they are wired to a computer than can do hd video.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 06:44 -
Converting large AVI files to smaller MKV
By vipertongn in forum Video ConversionReplies: 3Last Post: 26th Jan 2010, 19:07 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum CapturingReplies: 9Last Post: 13th Oct 2008, 16:38 -
Move OS from small hd to a large hd
By mysts in forum ComputerReplies: 8Last Post: 24th Feb 2008, 07:17
