    Jun 2010
    Milan, Italy
    hi,
    i have these big problem on my styler (written below)
    how could i fix these?
    please anybody help me.
    many thanks.
    ranee
    Generazione mený 1 di 3
    Prepara
    Crea un menu mpeg
    Multiplazione sottotitoli (bottoni) nel file mpeg
    Esecuzione comandopumux -s 0 "F:\\dvd-tmp\menu1-0.mpg_spumux.xml"
    DVDAuthor:pumux, version 0.6.14.
    Build options: gnugetopt iconv freetype
    Send bugs to <http://www.dvdstyler.de/support.html>
    INFO: Locale=Italian_Italy.1252
    INFO: Converting filenames to CP1252
    STAT: 0:00:00.000
    INFO: PNG had 1 colors
    INFO: PNG had 2 colors
    INFO: Pickbuttongroups, success with 1 groups, useimg=1
    INFO: Found EOF in .sub file.
    INFO: Max_sub_size=76
    INFO: 1 subtitles added, 0 subtitles skipped, stream: 32, offset: 0.50
    Statistics:
    - Processed 0 subtitles.
    - The longest display line had -1 characters.
    - The maximum number of displayed lines was 0.
    - The normal display height of the font arial.ttf was 0.
    - The bottom display height of the font arial.ttf was 0.
    - The biggest subtitle box had 76 bytes.
    Generazione mený 2 di 3
    Prepara
    Crea un menu mpeg
    Esecuzione comandopumux -s 0 "F:\\dvd-tmp\menu1-1.mpg_spumux.xml"
    STAT: 0:00:00.000
    INFO: PNG had 4 colors
    INFO: PNG had 5 colors
    INFO: Pickbuttongroups, success with 2 groups, useimg=0
    Assertion failed: useimg, file src/subgen-image.c, line 788
    This application has requested the Runtime to terminate it in an unusual way.
    Please contact the application's support team for more information.
  2. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    I haven't used that program, but this seems to be the error: Assertion failed: useimg, file src/subgen-image.c, line 788 That seems to refer to a problem on line 788, apparently in the subtitle files. Someone here may be more familiar with the program and have better advice.
    And welcome to our forums.
    Jun 2010
    Milan, Italy
    thanks a lot.
    i really hope someone could help.
    ranee
    Jun 2010
    Milan, Italy
    any way, how could this be solved?
    it would be great if someone can provide me the solution because i dont know how yo fix it.
    i used wundows vista home version, and re-install the dvdstyler but it appeared again.
    what is this spumux?
    it says to cantact the team.
    what should i do?
    please help me....
    million thanks
    ranee
