VideoHelp.com Forum
  1. Member Pr0metheus's Avatar
    Hi All,
    I am using WDTV HD Media Player for playing movies, which has specification of supporting x264 video up to High@L4.1 AVC profile, but some of the movies I have are in High@L5.1 profile, which causing blemishes in the image during the movie playback. What's the best app to re-encode video stream from High@L5.1 to High@L4.1?
  2. Member Pr0metheus's Avatar
    In case someone will need it, I've found it yet. XMedia Recode is perfect way to re-encode with various types of AVC profiles.
    In case you want to change only the profile level, try H264LevelEditor.
    It's free and can be found here:
    http://coolsoft.altervista.org/h264leveleditor
  4. tsmuxer import mkv> change 5.1 to 4.1 in level box select demux > remux mkvtoolnix
    tsmuxer level changer does the same as my H264LevelEditor, but requires three times as much HDD space:
    - 1 for the original MKV
    - 1 for the demuxed streams
    - 1 again for the remuxed MKV
    And also you must set again all tracks parameters before remuxing with mkvtoolnix (track name/language/delay).
    H264LevelEditor works in-line on the source file, no copy needed .
  6. thanks for advice
    Does not work for me on all 3 movies that I have tried so far. MediaInfo still reads as 5.1 and my LG still does not play. I will try to re-encode and post the results.
    Thanks for the tool though.
    EDIT:
    A few hours later (after viewing the movie) I must say that depending on the file, simply changing the header wont do the trick. I had to follow dylz advice and re-encode. Does not take that long (45mins to get the file changed but it does need HDD space) and finally my file was playable on my LG 3D TV. The level changer is worth the try though, since it does change the header in under a second. If it works, then you're done.
    Well, H264MediaInfo is just a shortcut for players that are mis-intepreting file headers, but it doesn't work for all of them.
    tsmuxer level changer does the same as my H264LevelEditor...
    Just a clarification, because I think that what I wrote is misleading.
    I didn't mean that the two softwares do the same thing, I meant they try to achieve the same result with two different approach. tsmuxer follows the right (and slow + HDD consuming) way, mine is a shortcut with in-place editing.
    You're right, thanks.
    Latest version has an UNDO feature, so trying it is really safe now .
  1. dvd rips in Format AVC profile : High@L5.1
    By vishal.cpr in forum DVD Ripping
    Last Post: 17th Sep 2011, 05:29
  2. DVD to AVC High Quality PSP Videos using Avi synth
    By ppeterr in forum DVD Ripping
    Last Post: 18th Jul 2010, 08:03
  3. Replies: 8
    Last Post: 3rd Jul 2010, 17:02
  4. Xvid VS X264 At High Bitrates
    By mohawkcr in forum Video Conversion
    Last Post: 4th May 2010, 16:18
  5. Conversion of x264 High Profile 5.1 MKV 1080p to accomodate GPU
    By cmwill3407 in forum Video Conversion
    Last Post: 27th Oct 2009, 23:18
