Hi what software can i use to edit/remove the other sound - languages - Subs etc from a full 42gb BluRay ISO.
Any help would be appreciated
AJ
Results 1 to 9 of 9
Thread: ISO of a BluRay?
Load the iso with DAEMON Tools or similar and rip with dvdfab decrypter.
sorry you need to mount the iso first with daemon tools or another iso loader.
Got it ...........................
Daemon Tools is a virtual Blu-ray/CD/DVD-ROM emulator. It is able to emulate nearly all known copy protections on the market today. Mount BIN/CUE, ISO, NRG, IMG, ISO files as a virtual CD-ROM or DVD-ROM or Blu-ray drive. -
The easy way to get what you want from a BLURAY is to use ANYDVD and TSMUXER. Use tsmuxer to mux what you want strait of the disc.Some disks are harder you will need something like Bluray inspector.You will need to use this while the disk is in the drive I have found.Just append each file as you go.
Or use clown_bd or clownbd bd copier to strip out stuff from a blu-ray. They can't work directly from a iso though.
PS3 Bluray ISO Mounting
By Westie69 in forum LinuxReplies: 1Last Post: 7th Jan 2011, 18:18 -
bluray iso back to bluray format
By mysts in forum Blu-ray RippingReplies: 3Last Post: 4th Jan 2011, 14:42 -
Bluray 3D iso to MKV convertor
By Humbug in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jan 2011, 10:24 -
Need a program to turn Bluray into iso
By adamf154 in forum Blu-ray RippingReplies: 1Last Post: 3rd Nov 2010, 16:34 -
Problems Playing Bluray ISO in PowerDVD 8
By aye29 in forum Software PlayingReplies: 5Last Post: 4th Sep 2008, 19:28
