Hi,
Can someone please recommend a USB capture card that supports the capturing of raw VBI (Vertical Blank Interval) data?
So far, I have tried a Dazzle and WinTV capture card, but they do not appear to read VBI.
I'm interested in capturing XDS data.
(I am using Ubuntu Linux, and the program "Zapping" and I receive the error "/dev/vbi0 is not a raw vbi device".
Thanks,
Jason
The ATI 550/650 drivers extract XDS data. You may need to use the ATI Windows App. or a Windows PVR app.
Not sure if MythTV uses XDS in Linux. I'd expect it to.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Thanks for the tip! I'm going to give the ATI 650 a try and see if I can read VBI.
Also, FYI - in case anyone else is looking, I found some other standalone tools
by searching for "usb vbi decoder".
Jason
Vertical lines with Pinnacle Studio 14/510 USB card
By karebo in forum CapturingReplies: 0Last Post: 11th Dec 2011, 15:54 -
No sound in WME with USB capture card
By bomb jack in forum CapturingReplies: 2Last Post: 25th Feb 2011, 03:40 -
USB or PCMCIA video capture card recommendation.
By quetzalin in forum CapturingReplies: 0Last Post: 21st Sep 2010, 05:50 -
EasyCap USB to S_Video Adapter Capture Card
By domainbug in forum ComputerReplies: 3Last Post: 7th May 2010, 20:51 -
USB 2.0 Video Audio capture Card
By jj3502 in forum CapturingReplies: 0Last Post: 3rd Feb 2010, 04:09
