Hi.
I have a several videos that I have taken with a small digital camera, and I am trying to figure out how to make a DVD that will play properly (especially audio/video sync) in a DVD player. I am looking for a freeware solution. Here are the details:
a) digital camera is Canon PowerShot SD870 IS Digital ELPH
b) videos are AVI files
c) I have not edited the AVI files in any way
d) "Gspot" reports the following information about the AVI files created by the camera:
-- OpenDML (AVI v2.0)
-- PCM Audio 44100Hz 706 kb/s (1 chnl)
-- Motion JPEG, Codec(s) are Installed
-- 14965 kbps 1.624 Qf
-- 30 Frames/s
-- 640x480
-- sar 4:3 par 1:1 dar 4:3
e) In addition, "VirtualDub" reports:
-- video: no delta frames
-- audio: PCM 16-bit (uncompressed)
f) the audio/video in the AVI files is perfectly in sync when played on my computer with Windows Media Player, MPlayer, VLC, and VirtualDub
g) I used DVD Flick to create a DVD-video from a few of the AVI files. The few AVI files I chose are much smaller than the capacity of the DVD. DVD Flick successfully created a DVD, but when played in a DVD player the audio and video are not in sync.
h) I tried using AVI2DVD. I got errors. Here is the log file:
AVI2DVD Started !
Type mode : Avi Input
Output : Dvd
Encoder Selected : QuEnc
Start demuxing the AudioStream No.1 ...
Demuxing of the selected audio finished successfully !
[K:\DVD\Avi2dvd_temp\Extracted_Audio.ac3 190524754 Bytes]
Starts Audio correction ...
Audio Fixed successfully !
[K:\DVD\Avi2dvd_temp\Fixed_Audio01.ac3 0 Bytes]
Starts Ac3->Ac3 convertion ...
Audio converted in Ac3 successfully !
[K:\DVD\Avi2dvd_temp\AudioStream 1 AC3 1CH.ac3 0 Bytes]
[9:53:46 AM] Job NOT Done. There are warnings ... Find at
the log file the 0 byte generated file to focus where exactly
the problem appears
I believe the problem is that the audio in my AVI is PCM, and AVI2DVD expects the audio in the AVI to be AC3.
Are there some options in DVD Flick or AVI2DVD that I am not setting correctly? Or do these programs not have the capability to do this properly?
Would any of the following freeware be able to produce audio/video synchronized DVD-videos from my AVI files: Avi2Iso, DeVeDe, DIKO, DVD2SVCD, DVDforger, FAVC, FilmMachine, or VidToDisc ? Or perhaps something else?
I suppose I could try them all, one by one, but I was hoping someone on this forum would know which (if any) of them would work.
Or perhaps I need to "do something" to the AVI files before I use them?
Thank you.
I don't use any of the software you refer to but PCM audio is fine for DVD. Though it needs to be 48 KHz, not 44.1 KHz.
Try loading all the AVI files into AVIDemux (load first file, "append" the rest), click the "Auto" tab, pick "Optical Disc ----> DVD", and save with file name of your choice with the ".mpg" extension. That will give you a DVD compliant video that you can "author" with any of several free applications.
You could try AVStoDVD. if the result is slightly out of sync, the script may be edited to either advance or retard the audio
to correct the problem.
https://www.videohelp.com/tools/AVStoDVD
Avi files "Not Support Video" on dvd player?
By aelfheah in forum DVD RippingReplies: 11Last Post: 12th Sep 2011, 12:18 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
Multiple AVI files on one DVD "not sure where to post"
By drifter666 in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2010, 19:44 -
Why do I have 2 files? "Movie Clip" and "M2V File"
By tygger in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2007, 21:55
