Hi guys!
I'd like to add some "smooth" to my input video. I mean, something like what "smoother" does in VirtualdubMod, but I'm now working with Avisynth. What avisynth plugin would you recommend, and could you also explain to me how to use/configure it? (an example script would be awesome!)
I've tried to use SmootherHiQ and found an example script too, but don't know what the parameters mean in it... any idea?
Thanks in advance!
	Smoother is a spacial denoiser in VirtualDub. I don't know if there is any exact equivalent but some filter like UnDot(), DeNoise(), Degrain(), MvDegrain(), MvDenoise(), FFT3D(), etc.
 http://avisynth.org/warpenterprises/
	He might also want to try something like Undot().FluxsmoothST(3,3) for some light-medium denoise. Fluxsmooth is a decent denoiser that is relatively fast. When I want to denoise, I generally use undot().fft3dfilter(sigma=1), but it is a bit slower than Fluxsmooth (but seems to keep more detail than fluxsmooth). Not sure what smoother was like in vdub since I have little experience with vdub for conversion. Consider installing AvsP and just tinkering with various denoisers and settings to see what you like for output.
	Well, basically what I'm trying to do is removing those annoying pixel marks from the video, which has probably been upscaled from low resolution flash video. Or just making it less annoying..
 Source:
 Output with vdubmod "smoother=100"
 Does a "random" avisnyth denoiser do this for me? If so, then I guess I'll have a go with FFT3DFilter, which I know at least a little bit (thanks to poisondeathray ) )
	You want to use a deblocking filter, not a noise reducer. Deblocking filters need to be run at the original frame size because they are optimized for 8x8 blocks (caused by DCT compression). Your sample images are 960x540 with 6x6 boxes and resizing artifacts. Hopefully you have the 1280x720 originals. Last edited by jagabo; 21st May 2010 at 16:01.
  AviSynth "ConvertToYV12()" command - correct placement in script?By spicediver10191 in forum Video ConversionReplies: 2Last Post: 11th Dec 2010, 20:15
  Filtering the cult series "Invader ZIM" using AvisynthBy rm2kpro in forum Video ConversionReplies: 6Last Post: 24th Jul 2010, 22:10
  Remove "Windowbox" scriptBy Tpiom in forum Software PlayingReplies: 1Last Post: 5th Jan 2010, 13:31
  Help. Avisynth Error Message "no function named deblock"By hypnoticpimp in forum Video ConversionReplies: 13Last Post: 28th Sep 2008, 00:45
  Seeking avisynth function for "blend-a-field" ideaBy vhelp in forum EditingReplies: 2Last Post: 21st Sep 2008, 21:52
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
