    Have a problem with jerky converted video that I posted about but was unable to solve. Home video .m2ts files play fine when I click on the file but are jerky when converted with Corel Movie Factory. So I'm trying AVStoDVD, using this guide http://adubvideo.net/how-to/convert-bluray-dvd-avstodvd. Converted file plays audio fine, but no picture just gray. Ideas?
  2. AVStoDVD Author _MrC_'s Avatar
    Hi jaco33,
    could you post the AVStoDVD project log file?
    Bye
    MrC
    AVStoDVD Homepage
    <5/21/2010 9:23:02 AM>
    START PROCESS
    PROJECT SETTINGS
    DVD Video Standard: NTSC
    DVD Titles number: 1
    DVD Size: 18/4450 MB (0%)
    DVD Output Setup: DVD Folder
    DVD Label: test 3
    DVD Menu: No Menu
    Output Folder: C:\Users\me\Videos\AVStoDVD test3
    Delete Temp Process Files: Yes
    Delete Working Files: Yes
    Edit Command Parameters: No
    Post Process Task: Show Progress Status window
    PREFERENCES
    AVS Source Filter: A2DSource
    AVS UpSize/DownSize Filter: Lanczos4Resize/Spline64Resize
    Video Resolution: 0
    Video BitRate Min: 2500
    Video BitRate Level 1: 6500
    Video Profile Level 2: 4500
    Video BitRate Max: 8500
    Keep DVD Compliant Video: 1
    AC3 Audio Encoder: 2
    DVD Audio Format: 0
    DVD Audio BitRate: 384
    Keep DVD Compliant Audio: 1
    Normalize Audio: 0
    DVD Audio Language: EN - English
    DVD Subs Language: EN - English
    Chapters Interval: 5
    Use Source Chapters: 1
    DVD Burning Drive: F: HL-DT-ST DVD-RAM GSA-E60L 1.00
    DVD Burning Speed: 4x
    Auto Erase DVD RW: 1
    Save Log file: 1
    Unload ActiveMovie library: 0
    Adjust ffdshow mixer: 1
    TITLE 1 SOURCE FILES
    Video: C:\Users\me\Videos\Sadie Jun09-Apr2010\20090503\20090503150446.M2TS
    Info: AVC - 6545 kbps - 1440x1080 - DAR 1.778 - 29.97 fps (CFR) - Interlaced (TFF) - 17 seconds - 521 frames
    Audio 1: C:\Users\me\Videos\Sadie Jun09-Apr2010\20090503\20090503150446.M2TS
    Info: AC3 - 256 kbps - CBR - 2ch - 48000Hz - 17 seconds - Internal
    Subs:
    [MediaInfoLib - v0.7.32]
    AVISYNTH SCRIPT
    Import("C:\Program Files\AVStoDVD\Lib\A2DSource.avsi")
    LoadPlugin("C:\Program Files\AVStoDVD\Lib\LeakKernelDeint.dll")
    Video = A2DVideoSource("C:\Users\me\Videos\Sadie Jun09-Apr2010\20090503\20090503150446.M2TS", CacheFolder = "C:\Users\me\AppData\Local\Temp")
    # Audio is frameserved by AviSynth just for Preview and Edit purposes.
    Audio = A2DAudioSource("C:\Users\me\Videos\Sadie Jun09-Apr2010\20090503\20090503150446.M2TS", CacheFolder = "C:\Users\me\AppData\Local\Temp")
    Video = Video.ConvertToYV12(interlaced = true)
    Video = Video.LeakKernelBob(1,7,false,false)
    Video = Video.Spline64Resize(720,480)
    Video = Video.SeparateFields().SelectEvery(4,1,2).Weave()
    AudioDub(Video, Audio)
    START VIDEO ENCODING OPERATIONS
    Encoding Profile: QuEnc CBR 1-pass
    Target Video FileSize: 17.2 MB
    QuEnc Parameters: -i "C:\Users\me\AppData\Local\Temp\test 3_0_20090503150446_1.avs" -o "C:\Users\me\Videos\AVStoDVD test3\test 3_0_20090503150446.m2v" -b 8500 -1 -hq -novbr -scene -trell -aspectratio 16:9 -interlaced -tff -mpeg2mux noaudio -dc 10 -priority 5 -auto -close
    <5/21/2010 9:23:42 AM>
    END VIDEO ENCODING OPERATIONS
    A2DVideoSource: DirectShowSource
    Created File: C:\Users\me\Videos\AVStoDVD test3\test 3_0_20090503150446.m2v (17.6 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 8500 kbps - 720x480 - DAR 1.778 - 29.97 fps (CFR) - Interlaced (TFF) - 17 seconds - 522 frames
    START AUDIO DEMUXING OPERATIONS (Track 1)
    FFmpeg Parameters: -i "C:\Users\me\Videos\Sadie Jun09-Apr2010\20090503\20090503150446.M2TS" -acodec copy "C:\Users\me\Videos\AVStoDVD test3\test 3_0_20090503150446_1.ToFix.ac3"
    <5/21/2010 9:23:43 AM>
    END AUDIO ENCODING OPERATIONS (Track 1)
    Created File: C:\Users\me\Videos\AVStoDVD test3\test 3_0_20090503150446_1.ac3 (0.5 MB)
    OUTPUT AUDIO INFO: AC3 - 256 kbps - CBR - 2ch - 48000Hz - 17 seconds
    START DVD AUTHORING OPERATIONS
    BatchMux Parameters: -arglist "C:\Users\me\AppData\Local\Temp\test 3_0_BatchMux.ini"
    BatchMux ini file:
    -d "C:\Users\me\Videos\AVStoDVD test3\test 3_0\VIDEO_TS"
    -mxp "C:\Users\me\AppData\Local\Temp\test 3_0_MuxMan.mxp"
    -l "C:\Users\me\AppData\Local\Temp\test 3_0_MuxMan.log"
    -muxman "C:\Program Files\AVStoDVD\MuxMan"
    -prio LOW
    -v "C:\Users\me\Videos\AVStoDVD test3\test 3_0_20090503150446.m2v"
    -vidmode LB
    -a1 "C:\Users\me\Videos\AVStoDVD test3\test 3_0_20090503150446_1.ac3"
    -a1lang en
    <5/21/2010 9:23:44 AM>
    CHECK DVD SIZE
    DVD Folder (actual) Size: 18.6 MB
    vs Estimated Size: 18 MB -> 3.3% oversize
    vs Assets Size: 18.2 MB -> OK
    END DVD AUTHORING OPERATIONS
    Created Folder: C:\Users\me\Videos\AVStoDVD test3\test 3_0 (18.6 MB)
    Log file created by AVStoDVD Release 2.3.0
  4. AVStoDVD Author _MrC_'s Avatar
    There are no issues in the log: DVD folder (VIDEO_TS) has been created correctly. Do you have problem in watching the video on the PC (what player are you using?) or on a standalone dvd player (burned DVD)?
    Bye
    MrC
    AVStoDVD Homepage
    Bye
    Converted file in Window Media Player and WinDVD, both have audio fine but picture is just blank gray (not black). If I click on the raw .m2ts file on my PC it plays video/audio fine on both WMP and WinDVD. I haven't burned it to disc because 1) I don't think the result will be any different than what I see on my PC 2) I can't get AVStoDVD to recognize my blank disc/burner --but one issue at a time I guess
  6. AVStoDVD Author _MrC_'s Avatar
    Let's try to deepen:
    1. Have you installed Haali Media Splitter and ffdshow (and ffdshow is setup to decode AVC)?
    2. Before starting the AVStoDVD project, if you use the 'Preview Clip' feature, do you get a grey screen?
    3. Have you tried to use Media Player Classic to play the resulting DVD?
    4. To test the standalone player, you can burn the VIDEO_TS folder into a DVD/RW disc with ImgBurn.
    5. If everything fails, could you upload the videoclip somewhere to have it tested?
    Let me know
    Bye
    MrC
    AVStoDVD Homepage
    I installed ffdshow and that did the trick. Thanks for your help!
    Off to my next problem, trying to figure out how to merge files.
