I've downloaded a movie in AVI format and I've tried to burn it to DVD using media player, windows dvd maker etc and all of them say that the file is too large, is there a way i can make it fit?
Some more info is needed. An AVI file to DVD requires it to be changed to DVD format if the result is expected to be playable in a regular DVD player. Give DVDFlick a try (free). There are many others available, also. If the file is already done to DVD specs and is just too big, try DVDShrink or DVD Rebuilder.
Yes you can make it fit. But you need to describe what you want to do.
1) Do you want to keep it in AVI format and burn that to a blank DVD disc with no conversion? If so, then you'll need to either burn to a dual layer disc (assuming the AVI will fit on that) or re-encode it down to a smaller size.
2) If you want to convert the AVI to DVD format, yes, it certainly can be done to get a smaller size. Some tools use bit rates by default that result in files that are too large for single layer discs. You could try DVDFlick as suggested or ConvertXtoDVD (not free) for example. -
I'm not really sure what i want to do, this is the first time ive tried to do this i just want to have a dvd that will play in my dvd player. i tried dvd shrink but it wont open the dvd file, it says it cannot find the specified file. how can i re encode something to a smaller size?
Avi file too large to burn to dvd
By MLPoison911 in forum Newbie / General discussionsReplies: 20Last Post: 12th Feb 2014, 13:07 -
How large a CONTIGUOUS file can I burn on a DVD-DL?
By tomreedtoon in forum MediaReplies: 24Last Post: 27th May 2013, 02:58 -
what do i do to make a dvd movie small enough to fit in one disc?
By polka in forum Authoring (DVD)Replies: 3Last Post: 24th Mar 2012, 01:53 -
.dv file too large to fit on FAT32 formatted hard drive - not sure of next step
By CBlanchard in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2010, 23:25 -
Large Video File to burn to dvd
By jbristow in forum Authoring (DVD)Replies: 8Last Post: 15th Jul 2007, 03:49
