HI !!
I've a Roadstar DVD 2014-H dvd player.
All was ok, when i've changed Video Output setting.
Now my screen is always black, no video signal.
I must reset settings or dvd player ... is it possible ??
If not, i need a guide to change Video Output setting with a black screen. I can't see what i do, but if i know the correct keys sequence, i can win !!
Need Help Please!!
Thank You!
Luca.
First guess you set it to progressive output or perhaps NTSC output but if you are in Europe you TV might be multi standard. Try unplugging the dvd player for a few miniutes and see if it resets the settings. Also try looking for the manual on the manufacturers website.
Hi !!
Yes ... it's the problem.
If is in NTSC mode, i can look it in black&white or not?? Or Progressive or NTSC, i MUST return do interlaced or Pal !!!!
Dvd Player is unplugged from 24 hours, but no reset.
No User Manual in Roadstar website and no manuals in the web. Only Service Manual.
If i open the player, is there a battery for settings ?? If yes and if a disassemby ... i can reset ? -
I don't have any personal experience with NTSC being fed to a PAL only display. Maybe the reset is holding down a button at power on?
Asus DVD 2014 L1T Writer fails for DVD +- DL
By fjmr in forum DVD RippingReplies: 8Last Post: 11th Aug 2008, 17:38
