Does this matter? Will the video look jerky or lose audio synch if a single frame is lost?
Depends on the frame, doesn't it? Like, if it's the final frame of black at the end of the movie -- who cares? Watch the video. If there's a problem, capture again.
At 29.97fps, the loss of one frame (if not accompanied also by the loss of the audio for that frame) will mean an audio desynch of 33ms, not enough to tell. There may or may not be a noticeable but very slight jerk or stutter at that place. If you're reencoding it for something, you can restore the audio synch by adding in a frame (duplicating an adjoining frame) using the Loop command of AviSynth followed by using the BadFrames filter on that frame to blend together the 2 adjoining frames. That'll effectively remove the stutter pretty much.
And if not reencoding, and even if reencoding and not frameserving using an AviSynth script, I don't think the problem is serious enough to worry about. -
Loop will also duplicate the audio for the frame, so will maintain any desync.
Better to use DuplicateFrame which doesn't touch the audio.Last edited by Gavino; 13th May 2010 at 04:33. Reason: Change FreezeFrame to DuplicateFrame
I don't include the audio in my scripts, so it wouldn't be a problem for me. Good to know, though.
DVD frame dropping.
By videosam in forum Video ConversionReplies: 20Last Post: 4th Aug 2010, 04:00 -
Single 2+ hour DVD file ripping to individual XviD files
By perceptionist in forum DVD RippingReplies: 2Last Post: 16th Mar 2010, 03:40 -
Flickering / Fluttering / Frame dropping...is this copy protection??
By mik534 in forum DVD RippingReplies: 9Last Post: 2nd Oct 2009, 06:55 -
Dropping frame with profile H.264
By n69 in forum Video Streaming DownloadingReplies: 2Last Post: 22nd Dec 2008, 21:41 -
is this pinnacle, dazzle or my new PC causing my frame dropping problems
By arthur1971 in forum Newbie / General discussionsReplies: 2Last Post: 10th Dec 2007, 02:41
