Results 1 to 13 of 13
  1. Member zoobie's Avatar
    Feb 2005
    Florida
    Hey now -
    I've decided to shoot time lapse with a 16:9 digital camera to match my HDV footage. However, I'm wondering what MP I need to do this. My HDR-HC5 HDV Handycam (CMOS) will shoot about 3MP at 16:9
    It seems someone said to use 8-10mp in the widescreen resolution but now I'm wondering if this is correct or overkill.
    A 12MP cam will shoot about 9MP at 16:9
    A 10MP cam will shoot about 7MP at 16:9
    A 6MP cam will shoot about 4MP at 16:9
    What's the story with matching my HDV? I would prefer to buy a dig cam that isn't total overkill.
    The goal is Blu-ray on HDTV.
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    All will be a downsize.
    What is your editor?
    Vegas and Premiere will autosize stills to HDV project format.
    Otherwise you need to match downsize to 1440x1080i with 1.3333 PAR
    http://www.kiva.org/about
  3. Member zoobie's Avatar
    Feb 2005
    Florida
    Thanks Ed for the reply. I'm running Vegas Pro 7 and VS 11 for quick edits.
    My HC5's manual says it's going to record 16:9 at 2304 x 1296 at 3MP
    I was planning on running CHDK on a Powershot for time lapse. Then I'd have a higher resolution like 7MP at 3264 x 1832
    Just wondering what's actually going to match the quality of my CMOS HDV.
  4. Member edDV's Avatar
    Mar 2004
    I thought you wanted to put stills into an HDV video project.
    Your manual is talking about taking stills with the camcorder.
  5. Member zoobie's Avatar
    Feb 2005
    Florida
    Yes...I plan on putting the stills into a HDV project in Vegas. I know my manual is talking about taking stills with the camcorder. But I've read that taking time lapse stills with a regular P & S cam results in better quality, flexibility, and hours in the field. That's why I'm leaning towards buying a compact cam at the mo...
  6. Member edDV's Avatar
    Mar 2004
    So if I understand, you want to take time lapse stills then output as HDV (or other HD standard) video to Blu-Ray?
    The quality of P&S level cam vs. HC5 will depend on the amount of zoom you will be doing and light levels. Most still cameras will take a higher resolution still but if you need to crop vs. zoom with the camcorder lens, or shooting in low light*, the quality advantage may shift to the HC5.
    Instead of HDV format consider 23.976p 1920x1080 for time lapse.
    * The HC5 has a 1/3 inch sensor and probably more glass. This combined with larger physical pixels (lower resolution) means other things being equal the HC5 will do better in low light than a smaller sensor point and shoot.
  7. Member zoobie's Avatar
    Feb 2005
    Florida
    My shots are all daytime outdoors on a tripod. My timelapses will probably be of sunsets, shadows, and clouds. I searched the internet and posted in different camera forums. Without any results, I figured the MP was probably a crapshoot.
    PS - The thing I like about Powershot CHDK is that you can shoot huge 16:9 and even turn off the LCD between shots extending the battery life by hours. This simplifies things when shooting for 5 hours.
  8. Member edDV's Avatar
    Mar 2004
    The Powershot should do fine. I don't recall if the HC5 has adequate manual exposure controls to pull that off over 5 hrs
  9. Member zoobie's Avatar
    Feb 2005
    Florida
    This was posted in another forum:
    HDV image is only 2 megapixels, so basically any still camera that takes 3 MP shots or better is good enough for HDV timelapse. I have used DSLRs and resized the shots to 2000 pix wide using midquality JPG compression (which is still much better than native HDV).
    so, according to this, a new 14MP camera would be a huge overkill if only requiring 3MP
  10. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    only in a strictly technical sense. other factors are more important. an oversized jpeg can always be resized to 1920x1080. a 14mp camera with a cheap plastic lens would create crap anyway. any 3-5mp camera these days is going to be low quality point and shoot. a decent mid priced camera like the newer nikon p100 might be nice and is able to shoot 1920x1080p if you want video from it.
  11. Member 2Bdecided's Avatar
    Nov 2007
    I think the entire discussion is missing the point - what matters is whether the chosen camera takes decent, pleasing (well exposed, in-focus, reasonably sharp) pictures. If it does, then anything from the last five years is going to be fine in terms of pixel count, and more than a match for the image from an HDV camcorder.
    Where do you find a camera these days that can't produce a decent looking 2MP image outdoors on a tripod?! In a Christmas cracker?!!?!!
    Draw or tape 16x9 markers on the view finder (unless the camera support a 16x9 mode - which doesn't matter in the slightest because it's trivial to crop).
    Cheers,
    David.
  12. Member zoobie's Avatar
    Feb 2005
    Florida
    Well, everyone's altruistic needs and deeds are appreciated...
    We may be mixing apples (Handycam CMOS) with oranges (Powershot CCD)
    I did learn that HDV was about 2MP, though...give or take
    I'll first try my little HC5 which shoots 16:9 at 3MP time lapse stills
    Then, with the same cam, I'll try cropping 4:3 at 4MP timelapse stills to 16:9 to compare
    The DSLR that shoots HDV will just have to wait a few years until I first wear out this little handycam
    Hey...I just saved $2,000
    Damn I'm good
  13. Member edDV's Avatar
    Mar 2004
    Normal HDV is 1440x1080i @ 25Mb/s with 1.333 PAR same as HDCAM and normal AVCHD @17 Mb/s.
    If you want to pull a square pixel still to an HDV timeline, the still must be horizontally squeezed to 1.333 PAR.
    1440 x 1080 = 1.55 megapixels.
    When resampled to square pixel 16:9 display
    1920 x 1080 = 2.07 megapixels.
    If you downsize to a square pixel 1920x1080 timeline, you don't need to upsample from HDV.
