Hello.
I was wondering if there is any way to embed subtitles to a single video file giving the option to the viewer to turn the subtitles on and off.
Simple question, impossible task most probably I know!
Thanks.
A.
Are we talking about DVD? If so, it is done all the time. You just need decent DVD authoring software that can mux the subtitles with audio and video streams and create menus to select subtitle options.
In the case of Divx/Xvid avi files, you can easily add subtitles and use the avi playback device to switch subs on and off.
This is everyday stuff; not impossible at all...if you're willing to take the time to learn. -
Hello and thanks for replying.
I'm only talking about a single video file, not DVD. And I definitely don't want the subtitles to be hard coded onto the video.
Also, I don't want to have a separate subtitle file to go along with the video.
So this is possible with AVIs? Could this be achieved with any other video format btw (mpg, wmv)?
Thanks again.
A. -
Easy peasy, happens all the time. Not possible with AVI (except the .DIVX flavor of it, if played on DivX-certified players). Instead, use MKV. You just mux the SRT/ASS subtitle file(s) together with the video and audio tracks. Each SRT/ASS file becomes a selectable subtitle track in the final MKV.
MP4 should be capable of the same but I'm not familiar with its supported subtitle formats. Don't know about MPG and WMV. -
It's possible to embed subtitle streams in an AVI, yes. I used to embed .srt streams in AVIs all the time, primarily for use with my DVP-642 DVD player. Worked just like any normal switchable subtitle stream on that player, and all my computer-based players.
I've also seen .ass subtitles embedded in (and also working) in AVI files. Granted, hardly anyone ever does that, as they do work better in MKV files (as you can embed things like the necessary font files, for example), but it was still possible.
The AVI-Mux GUI 'Myths about AVI' page does explain a little about it. Somewhat.
(I'm not recommending the use of AVI for softsub streams, necessarily, but it IS possible.)If cameras add ten pounds, why would people want to eat them?
How to embed .ASS subtitles into video image?
By lordsmurf in forum SubtitleReplies: 1Last Post: 27th Nov 2011, 23:03 -
How to capture optional subtitles?
By standmenow in forum Video Streaming DownloadingReplies: 0Last Post: 5th Dec 2009, 10:21 -
Embed subtitles onto video
By Burnerneil in forum SubtitleReplies: 2Last Post: 20th Aug 2009, 15:30 -
how to embed subtitles in a video?
By mai_hnf in forum DVD RippingReplies: 1Last Post: 1st Sep 2007, 22:22 -
dvd conversion with optional subtitles
By FordyH in forum Newbie / General discussionsReplies: 9Last Post: 15th Jul 2007, 00:54
