I'm I've recently converted my garage into a bar and I've wired for 4 speakers in each corner of the room. I'm having two TV`s in there so I've wired HDMI, SCART, VGA and PHONO leads to each TV. All the cables go back to the same place where I'm going to have my DVD player etc. The problem I've got is, what would i need to play the audio from the TVs through the speakers with out having to messing about swapping the cables in the back of the DVD player etc for each TV all the time. Is there a unit of some sort in which i can just plug all the cables in and use a remote to select which TV i want to play through the speakers?
Thanks Dave
Results 1 to 1 of 1
One sided right bar in Virtualdub ...
By holeepassion in forum Newbie / General discussionsReplies: 13Last Post: 22nd Apr 2012, 14:16 -
How to get rid of this nav bar
By SignedupGuest in forum Newbie / General discussionsReplies: 4Last Post: 15th Mar 2012, 20:40 -
Wii Sensor Bar
By Squid_uk in forum Off topicReplies: 5Last Post: 26th Jun 2009, 20:03 -
ffmpeg seek bar (or timing bar)
By Seven40Rob in forum ffmpegX general discussionReplies: 1Last Post: 7th Oct 2008, 23:36 -
green vertical bar on left, purple verticle bar on right, source B&W VH
By lipwak in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th Jul 2008, 21:29
