Okay, I got this used Panasonic E25S dvd recorder not long ago and everything seemed fine and then one day I used the TV tuner to setup a recording of a television program. The language was mexican if routed through the DVD recorder, but english if piped through the TW cable box...weird.
Next I wanted to record a program on the History Channel, no sound! The live broadcast has sound, and when I switch between the Cable and DVD tuners sometimes I get sound, no sound, music, or another language.
Sounds like you're setup to record the SAP channel. Occasionally that channel will have Spanish and occasionally it will have nothing and sometimes it just has a duplicate of the main English soundtrack.
I'm not near my Panasonics now but I believe you select main or secondary audio somewhere in the SETUP menus or maybe push the STATUS button, just can't remember now. -
Thanx jjeff, I think that I found the corrective action under the "status" button. I have it set as "stereo" and now it seems to work fine; good thing because I cannot understand mexican.
Panasonic DVD Recorder - Spindle needs cleaning
By lacywest in forum DVD & Blu-ray RecordersReplies: 30Last Post: 20th Oct 2014, 23:20 -
Convert DVD with choice of audio language and burned-in subtitle language
By theproof in forum DVD RippingReplies: 2Last Post: 24th Jun 2010, 17:34 -
How Panasonic DMR-E80H convert japanese to english Language
By tanveerriaz in forum DVD & Blu-ray RecordersReplies: 0Last Post: 9th Feb 2010, 07:30 -
panasonic tv bush dvd recorder going mad
By mondeoglx in forum DVD & Blu-ray RecordersReplies: 1Last Post: 2nd Jan 2008, 11:05 -
Panasonic DVD Recorder, no multi region, what to do?
By girl_alliene in forum DVD & Blu-ray RecordersReplies: 2Last Post: 20th Sep 2007, 10:43
