    Oct 2009
    I have two avi files which are about 1/2 gig in size each. I would like to join these together as one file that can be watched all the way through. What is the best way to do this without losing quality?
    Thanks,
    TC
    My Dell PC system info.....3.4 Ghz Quad Core i7 processor....... 12 gigs of ram DDR3...... Windows 7 ultimate 64 bit.......video card Nvidia GTX 650
  2. Member t0nee1's Avatar
    Dec 2006
    Here,where do you think?
    Well, simply fire up Avidemux-> File->Open, load first avi->File-> Append-> add 2nd avi, set 'Copy for VIDEO and Audio and save as new.avi, making sure to include the file extension..That's one way of doing it..
    "I typed the word Google into Google. Guess what came up? Everything."
    "What we've got here is failure to communicate"
  3. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Unless they have the same exact properties one will need to be re-encoded to match the other resulting in quality loss.
    Oct 2009
    The two avi files that I was trying to merge do have the exact same properties and they were encoded with the exact same software. So I am fine in that regard.
    I took the suggestion above(avidemux) and that did work well.
    Also, in case anyone else ever stumbles across this post and has the same issue....... i found a free program which can join avi files and also a few other file types. It is not as powerful as avidemux but it is easier to use. It is called "ez joiner." They do ask you to register this product, but it is still no charge.
    http://doeasier.org/joiner/downloads.html
    TC
