How do I finalize a DVD? What is ImgBurn? Is it compatible with Windows 7? Is it easy to use, most important is it safe to use on my computer. Any information is helpful. Thank you, PD
Thread: Finalizing a DVD
ImgBurn is THE BEST.
Finalizing a DVD is usually NOT necessary if burned with a computer.
Finalizing is usually only an issue with DVD Recorders.
the DVD was burned on my computer and it was not finalized. I reburned the DVD thinking I had done sometime wrong. It once again did not finalize, it would not play in my DVD player, saying it had not been finalized. Do you suggest I download ImgBurn? Is it compatible with Windows 7? Thank you.
Are you burning RW discs?
What computer program did you use to burn with?
I'm using DVD- R discs. I'm using the program on my computer with windows 7.
Unless you are burning a VIDEO_TS folder or an ISO image of a DVD to a blank DVD-R....I think you have
more serious problems than "finalizing". Not computer problems...lack of knowledge problems. No offense intended.
Windows Vista and 7 use UDF 2.01 which isn't compatible with DVD-Video which uses UDF 1.02.
Use ImgBurn and your burning problems will go away, now if you have authoring problems that's a different story.Last edited by MOVIEGEEK; 29th Mar 2010 at 14:49.
Definitely a lack of knowledge. Help! How would I find out about authoring problems?
Finalizing a DVD
By gmcsew in forum MacReplies: 24Last Post: 18th Jul 2009, 22:07 -
Messed up finalizing a dvd
By spunon in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2009, 14:06 -
DVD finalizing problems
By 1234567 in forum Authoring (DVD)Replies: 3Last Post: 22nd Nov 2008, 22:11 -
Finalizing DVD Disc
By POOLADY1 in forum Newbie / General discussionsReplies: 5Last Post: 22nd Feb 2008, 13:54 -
how to finalizing a dvd+r ...
By jvlbr in forum Newbie / General discussionsReplies: 6Last Post: 6th Jul 2007, 21:29
