Results 1 to 14 of 14
    Apr 2008
    Netherlands
    Hi,
    I'm trying to convert a mkv file to a dvd but I want the audio to stay surround.
    All the converters I tried made it in to 2.1 sound.
    Its a .264 file... I allready demuxed the mkv to 3 files .264 .dts and .sup(subtitles arent needed).
    Can anyone help me?
    I'm trying AVStoDVD atm but not sure it this works..
    Oh now I see similair threads.. http://forum.videohelp.com/threads/286449-DVD-to-MKV-while-keeping-DTS-and-AC3
    Trying http://www.videohelp.com/tools/AutoMKV
    I did use the search but this didnt come up.
    Apr 2004
    Miskatonic U
    AVStoDVD should work if the box marked Keep DVD compliant Audio is ticked, except if the DTS audio comes from a BluRay DTS HD sound track. This apparently has some issues at the moment, but will be fixed in a future release.
    That said, depending on the film, there may be only 2.1 audio, even in a DTS track. The Criterion release of Sanjuro has DTS audio that is 2.1. MediaInfo can confirm this.
    For DVD I would suggest converting the DTS to AC3 448 kbps if only to get more space for the video, unless you are converting fopr dual layer.
    Read my blog here.
    Apr 2008
    Netherlands
    I tried avstodvd but it came out without audio .
    PREFERENCES
    AVS Source Filter: A2DSource
    AVS Resize Filter: Lanczos4Resize
    Video Resolution: 0
    Video BitRate Min: 2500
    Video BitRate Level 1: 6000
    Video Profile Level 2: 4500
    Video BitRate Max: 8500
    Keep DVD Compliant Video: 1
    AC3 Audio Encoder: 0
    DVD Audio Format: 0
    DVD Audio BitRate: 192
    Keep DVD Compliat Audio: 1
    Normalize Audio: 0
    DVD Audio Language: EN - English
    DVD Subs Language: EN - English
    Chapthers Interval: 5
    Use Source Chapters: 1
    DVD Burning Drive: G: TSSTcorp CDDVDW SH-S223F SB02
    DVD Burning Speed: 4x
    Auto Erase DVD RW: 1
    Save Log file: 1
    Unload ActiveMovie library: 0
    Adjust ffdshow mixer: 1
  4. It could be exactly what guns1inger was saying: a "problematic" DTS track may lead to error like yours (track is demuxed, probably with errors, but MuxMan, the authoring software, does not accept it).
    Two possibilities: download latest AVStoDVD 2.3.0 Alpha (which has a better control on DTS tracks) or force AVStoDVD to re-encode it to AC3 (which is what new Alpha does if it gets errors during DTS demuxing step).
    Bye
    MrC
    AVStoDVD Homepage
    Apr 2008
    Netherlands
    Thanks trying that .
    Tried AVI2ISO as well but that came up with a error msg.
    Apr 2008
    Netherlands
    Gave me error msg straight away:
    <29-3-2010 9:38:06>
    START PROCESS
    <29-3-2010 9:38:06>
    PROJECT SETTINGS
    DVD Video Standard: PAL
    DVD Titles number: 1
    DVD Size: 4450/4450 MB (100%)
    DVD Output Setup: DVD Folder
    DVD Label: DVD
    DVD Menu: No Menu
    Output Folder: D:\enc\Nieuwe map
    Delete Temp Process Files: Yes
    Delete Working Files: Yes
    Edit Command Parameters: No
    Post Process Task: Show Progress Status window
    PREFERENCES
    AVS UpSize/DownSize Filter: Lanczos4Resize/Spline64Resize
    Video Resolution: 0
    Video BitRate Level 1: 6500
    DVD Audio Format: 0
    Keep DVD Compliant Audio: 1
    Normalize Audio: 0
    Chapters Interval: 5
    DVD Burning Drive: G:\
    Save Log file: 1
    <29-3-2010 9:38:06>
    TITLE 1 SOURCE FILES
    Video: F:\Encounters.At.The.End.Of.The.World.mkv
    Info: AVC - 4578 kbps - 1280x720 - DAR 1,778 - 23,976 fps (CFR) - Progressive - 1:40:38 hours - 144912 frames
    Audio 1: F:\Encounters.At.The.End.Of.The.World.mkv
    Info: DTS - 1536 kbps - CBR - 48000Hz - 6ch - 1:40:44 hours - Internal
    Subs:
    [MediaInfoLib - v0.7.29]
    <29-3-2010 9:38:06>
    AVISYNTH SCRIPT
    Import("C:\Users\Laurens\Downloads\AVStoDVD_230Alp ha100323_NoInstall\Lib\A2DSource.avsi")
    Video = A2DVideoSource("F:\Encounters.At.The.End.Of.The.Wo rld.mkv", CacheFolder = "C:\Users\Laurens\AppData\Local\Temp")
    # Audio is frameserved by AviSynth just for Preview and Edit purposes.
    Audio = A2DAudioSource("F:\Encounters.At.The.End.Of.The.Wo rld.mkv", CacheFolder = "C:\Users\Laurens\AppData\Local\Temp")
    Video = Video.ConvertToYV12
    #Using DGPulldown/HCenc to upsize FPS
    Video = Video.Spline64Resize(720,576)
    AudioDub(Video, Audio)
    <29-3-2010 9:38:06>
    START VIDEO ENCODING OPERATIONS
    Encoding Profile: HCenc VBR 1-pass
    Target Video FileSize: 3246,6 MB
    HCenc Parameters: -ini "C:\Users\Laurens\AppData\Local\Temp\DVD_0_Encount ers.At.The.End.Of.The.World.HCenc.ini"
    HCenc ini file:
    *INFILE C:\Users\Laurens\AppData\Local\Temp\DVD_0_Encounte rs.At.The.End.Of.The.World_1.avs
    *AVSRELOAD
    *OUTFILE D:\enc\Nieuwe map\DVD_0_Encounters.At.The.End.Of.The.World.m2v
    *LOGFILE C:\Users\Laurens\AppData\Local\Temp\DVD_0_Encounte rs.At.The.End.Of.The.World.HCenc.log
    *MAXBITRATE 9000
    *1PASS
    *BITRATE 4506
    *PROFILE BEST
    *ASPECT 16:9
    *PROGRESSIVE
    *BIAS 50
    *DC_PREC 9
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *WAIT 2
    <29-3-2010 9:39:42>
    PROCESS ABORTED DURING TITLE 1 VIDEO ENCODING OPERATIONS.
    CHECK LOG FILE <D:\ENC\NIEUWE MAP\DVD_0.LOG> FOR MORE INFO.
    <29-3-2010 9:39:42>
    Log file created by AVStoDVD Release 2.3.0 Alpha build 100323
    Apr 2004
    Miskatonic U
    I would start by simplifying the file name. Get rid of all the spaces, periods etc. Call it movie.mkv, then try again.
    Read my blog here.
  8. Have you tried to use the 'Preview Clip' feature before start encoding? Any errors messages?
    Bye
    MrC
    AVStoDVD Homepage
  9. If anybody would help to unveil the DTS mystery...
    Bye
    MrC
    AVStoDVD Homepage
    Apr 2008
    Netherlands
    File name was allready movie.mkv, previewing gives error msg: Script error: there is no fucntion name Spline64resize c:\users\laures\appdate\localtem\avisyntp.avs line 9
  11. Originally Posted by Loonatik View Post
    That's very strange, because Spline64Resize() is a standard AviSynth 2.5.8 function. Try to re-install AviSynth. If it doesn't work, post here the c:\users\laures\appdate\localtem\avisyntp.avs file.
    Bye
    MrC
    AVStoDVD Homepage
    Apr 2008
    Netherlands
    I used the no installer package(alpha) so I cant reinstall(tried redownloading but didnt help).
  13. MrC
    AVStoDVD Homepage
    Apr 2008
    Netherlands
    No installer is standalone.
