Dear friends,
I have been successful in using "ArcSoft MediaImpression for Kodak" to create 720p/60 MOV files that play on the Kodak Zx1 Pocket Video Camera. I simply copy the MOV files so created to the camcorder's SD card, where they are recognized and can be played without problem.
However, I have not yet been successful in using ffmpeg to create 720p/60 MOV files that play on this camera. I have tried using H.264 Access Unit delimiters and have even pasted a special "udta" (user data) atom into the "moov" atom that appears to be necessary for playback.
Here is a sample ffmpeg command line that I have been using to try to create a playable MOV file:
>ffmpeg -s hd720 -r 59.94 -i 102_0004.yuv -r 59.94 -vcodec libx264 -b 15000k -flags2 aud 102_0005.MOV
where 102_0004.yuv was created from 102_0004.MOV (a short clip created by the Zx1) as follows:
>ffmpeg -i 102_0004.MOV -pix_fmt yuv420p 102_0004.yuv
Any suggestions?
Results 1 to 9 of 9
anyone else have any hints on how to convert source video to something the device will play?
This is what the files generated by the device follow but I cannot replicate the exact same settings with some of the software I've tried (Super, Handbrake, Media Impression for Kodak, etc)
Code:Format : MPEG-4 Format profile : QuickTime Codec ID : qt File size : 59.3 MiB Duration : 44s 244ms Overall bit rate : 11.2 Mbps Movie name/More : KODAK Zx1 Pocket Video Camera Encoded date : UTC 2010-01-30 10:00:36 Tagged date : UTC 2010-01-30 10:00:36 Origin : Digital Camera AMBA : Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Frame mode : Frame doubling Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 44s 244ms Bit rate mode : Variable Bit rate : 11.1 Mbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 fps Original frame rate : 14.985 fps Resolution : 8 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.401 Stream size : 58.4 MiB (99%) Title : Ambarella AVC / Ambarella AVC Language : English Encoded date : UTC 2010-01-30 10:00:36 Tagged date : UTC 2010-01-30 10:00:36 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format version : Version 4 Format profile : LC Format settings, SBR : No Codec ID : 40 Duration : 44s 53ms Bit rate mode : Constant Bit rate : 128 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Stream size : 688 KiB (1%) Title : Ambarella AAC / Ambarella AAC Language : English
Thank you for your posts.
I have been successful in creating MOV files in ArcSoft MediaImpression (v2.0.24.586) that play back on the Zx1. This is what I did:
1. I imported the file (in this case a standard-definition WMV file) into ArcSoft's Media Player
2. I selected the Save/Share button and selected "PC" format
3. I clicked on the "Advanced" button and selected MOV(720P) file format and 59.9 fps. It warned me about the change in aspect ratio.
4. After clicking "OK", MediaImpression converts the file to MOV.
5. I renamed the file to a naming format recognized by the Zx1 (e.g., 113_0099.MOV).
6. I transferred the MOV file to the Zx1's SD card. It was recognized in the thumbnail view and played correctly. -
Thanks misnardi for that post. The ArcSoft software is pretty terrible but you're right, if you use their 'create movie' feature you can convert your content to MOV that is playable on the ZX1. The goofy thing is that if you use their conversion feature the ZX1 isn't listed as a output device and none of the other Kodak output templates work either.
At least I can use the ZX1 as a playback device now, thanks for you reply.. It is much appreciated.
Hopefully someone will figure out what is missing when using other software to convert to the MOV container. Sure would be nice if Kodak had some actual documentation or support on this matter. -
Agreed. I am also starting to perform experiments to deduce which QuickTime atoms are required for playback on the Zx1. I start by capturing a MOV clip on the Zx1. Then I use a hex editor to search for and replace an atom's 4-character type with the characters 'free'. This essentially forces the player to ignore that atom and any information it contains. After modifying an atom's type, I see whether the modified MOV slip is still playable on the Zx1.
With a test MOV clip, I so far found that the following atoms are NOT essential for playback:
- sound 'trak' (when this atom is converted to free, the sound stops playing on the Zx1)
- video 'edts'
- video 'tapt'
- video 'dinf'
- video 'hdlr' (in minf atom)
- video 'stsc'
- video 'sdtp'
I so far found that the following atoms ARE essential for playback:
- video 'stss'
- video 'ctss'
- video 'stco'
- video 'stsz'
- moov 'udta' (user data atom)
- moov udta 'AMBA' atom
This last atom, AMBA, appears to be a proprietary atom which is required for playback. I cannot find any documentation for it online. Since FFMPEG does not insert an AMBA atom in the user data atom, this could contribute to the reason why FFMPEG MOV files don't play back on the Zx1 (at least that is my theory).Last edited by misnardi; 6th Apr 2010 at 15:36.
The camera can act as a portable, inexpensive test pattern or signal generator. I like to test consumer flat panel displays with specialized A/V HD test patterns that I create, and having the ability to plug the Zx1 into the flat panel display via HDMI is a very handy thing.
The device comes boxed with composite video and audio cable, it is easily plugged into my DVD player in my car making it VERY easy for me to keep the kids entertained while travelling (as opposed to carting around a bunch of DVDS).
buy a few 4gb SD cards and I'm set for those long road trips, no more screaming kids.
I haven't found any decent QT Atom viewer/editor and some of the libraries/source I've seen (I'm a Java developer) doesn't work or craters the application when trying to load a sample MOV file from the camera.
If there were better examples on adding a new ATOM (AMBA) then I could probably write some source to 'update' any MOV file that was missing the ATOM but met the video/audio requirements.
Sadly I know nothing about the MOV container (or AV containers for that matter)
How to convert MOV files created by a Kodak digital camera
By peliopoulos in forum User guidesReplies: 19Last Post: 21st Sep 2012, 11:31 -
Problem padding with ffmpeg
By joesphroth in forum Video ConversionReplies: 8Last Post: 6th Dec 2011, 18:56 -
Several movs/mpgs to DVD / Quality decreases on best files
By soundchaser in forum MacReplies: 4Last Post: 2nd Nov 2010, 11:04 -
problem converting swf created by jing capture
By surfmonkee in forum Video ConversionReplies: 2Last Post: 22nd Feb 2010, 05:33 -
Audio Format created by VOB2MPEG - problem
By linesma in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 3rd Jan 2008, 11:46
