Is it possible to convert multiple Avi's to DVD using Vegas Pro then author in DVD Architect? I read briefly on another forum (which I can't find again) that it was possible. Any assistance would be appreciated. Thank you.
if you don't know what vegas does or how to use it, you would be better off using something like convertxtodvd which will take several avi files and make a dvd for you.
Too vague.
What sort of avi files ? mediainfo tree view is good for this.
Do you want multiple titles on the DVD ?
Are you doing any editing before you encode for DVD ?
Vegas is designed for editing. You work on a single video at a time. If you are going to create a DVD, you edit, then output the video/audio encoded as DVD compliant mpeg-2/AC3. Repeat for all your titles. Once you have all your video finished and ready, open DVD Architect, import your titles, and create a DVD.
If your AVI files are just downloaded movies/episodes, use convertXtoDVD or AVStoDVD instead, as Vegas is not designed for this type of work.Read my blog here.
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 08:27 -
Sony Vegas Pro 8 ... transitions application on multiple video clips ???
By holeepassion in forum Newbie / General discussionsReplies: 3Last Post: 20th Feb 2010, 01:04 -
Hello..been a long time-Can I upgrade from vegas 5.0 and DVD arch 2.0 to Vegas Pro 9
By arcorob in forum Newbie / General discussionsReplies: 6Last Post: 1st Feb 2010, 20:31 -
VEGAS PRO - How to SELECT & DRAG multiple clips at once
By reniet in forum EditingReplies: 3Last Post: 19th Dec 2008, 20:22 -
Sony Vegas 8 Pro Question - How to crop entire movie with multiple videos?
By Mysteriouskk in forum Newbie / General discussionsReplies: 4Last Post: 5th Mar 2008, 19:50
